Bazda wrote:maybe its leaking cos you got alot of crank pressure, which maens u need some better breathers on the rocket covers.
I had to put 2 inlet covers on my 4agte so I can vent the exhaust side pressure and it was fine after that, no more leaks.
Trls250s wrote:You can run a redtop/bluetop dizzy as a CAS as it has a crank angle sensor in it.
This is how the NA engines get there crank angle readings. I know many guys who modify normaly dizzy to coil setup and just make a plate that goes over the unit instead of that plastic cover so its smaller as well (good for putting 20v's in rwd's)
HRT wrote:[quote="matt dunnSmallport only, as the other have different number of teeth in them,
4 pulse and 24 pulse, as opposed to 4AGZE, Smallport and 20V which are
1 pulse and 24 pulse.
escortman wrote:huh that confused me, but i do hav a smallport dizzy so if i need to run that how do i do it?
escortman wrote:o and wat about the coil packs? spark plugs how shud i set that up ?
