so.. Shudder only under clutch motion..
Clutch is very simlar to this..
As seen here..
What could be the causes for clutch judder (chatter or shudder)?
Judder can be the result of any number of problems. Possible causes
may be as follows:
1. Improper break-in procedure.
2. Flywheel was not properly resurfaced before the new clutch
was installed.
3. Flywheel is not parallel, or the friction surface is out of parallel
with the crank flange surface.
4. Flywheel was not resurfaced properly or has an improper surface finish.
5. Flywheel has severe hard spots or hot spots.
6. Flywheel has an improper step or cup dimension.
7. Damaged or excessively worn CV joints.
8. Bad u-joints in driveshaft or u-joints misaligned.
9. Excessive backlash in differential.
10. Excessive driveline angle.
11. Bad leaf springs, bushings or mounts.
12. Improper gear ratio versus tire diameter.
13. Defective pressure plate and/or disc.
14. Disc has inadequate or no marcel—not enough cushion between
friction facings.
15. Oil or grease contamination on clutch facings.
16. Worn or damaged clutch linkage.
17. Bent cover assembly and/or disc.
18. Improperly tuned engine.
19. Worn or damaged engine mounts or transmission mounts.
Adydas wrote:Problem solved.. none on that list.
Okay, so what now? is there any damage, do you have to start from scratch?Adydas wrote:Bearing installed the wrong way around.. wouldnt fully dissengadge..
Users browsing this forum: Bing [Bot] and 25 guests
