setting up external wastegate port
Postby l1ttle_d3vil » Wed Feb 13, 2008 9:56 pm
going to set up an external wastegate for my 4agte manifold soon. its a pretty standard top-mount steamtube manifold, roughly equal length runners etc.
is there a "best" place to put the wastegate port? does it matter if its off one exhaust port, or is it better coming from two for a more even "vent" ??
will be running around 18psi so needs to vent reasonably freely i guess. would rather find out what not to do now rather than later! :D
Postby IH8TEC » Wed Feb 13, 2008 9:58 pm
generally right at the collector is the best place, that way its pretty much where you can get it from all 4cylinders.
Postby ChaosAD » Wed Feb 13, 2008 10:37 pm
is it a twinscroll turbo?
ChaosAD
Postby IH8TEC » Wed Feb 13, 2008 10:39 pm
if it's twinscroll you still take it from same area, jsut one off each pair
Postby l1ttle_d3vil » Thu Feb 14, 2008 8:01 am
sweet as that makes sense. its just a standard garrett t25 off an s13.
Postby ~SlideWays~ » Thu Feb 14, 2008 8:59 am
Wow I can't see a T25 lasting long at 18psi!?
Just a heads up though. 8O
~SlideWays~
Postby evil_si » Thu Feb 14, 2008 9:32 am
meh at 18psi it wont need to vent much as it will be closed most of the time to create that boost,
go off the collector, dont go off 1 runner as it will surge,
and doesnt sound or feel very cool at all
evil_si
Postby l1ttle_d3vil » Thu Feb 14, 2008 1:40 pm
~SlideWays~ wrote:Wow I can't see a T25 lasting long at 18psi!?
thanks :lol: what do you think the most boost would be for a t25?
Postby ~SlideWays~ » Thu Feb 14, 2008 2:33 pm
I ran 12psi on my old T25g (.80a/r vs normal .48 ) and had no probs. But 18 is gunna be pushing it on the poor old thing.
Im sure the internet will know :)
~SlideWays~
Postby touge rolla » Thu Feb 14, 2008 4:32 pm
A friend of mine is running 14psi in his Avenir GT4Z, no other mods, and no problems :)
touge rolla
Postby l1ttle_d3vil » Thu Feb 14, 2008 8:01 pm
just had a look at the turbo and the a/r's are .80 on the front and .64 on the exhaust side. those numbers don't mean a hell of a lot to me, but i think smaller = faster spool, bigger = better top end right?
is the issue just going to be getting to 18psi? or the turbo letting go before it gets there? :lol: its a genuine garrett turbo.
Postby MRDRFT » Thu Feb 14, 2008 9:44 pm
yer the t25 wil struggle to do 18psi,and if it does do it, it wont last long as the turbo will just get to hot and workin to hard,try get a t28 off a s15 silvia they will do 18 but still pushing it,
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby evil_si » Fri Feb 15, 2008 7:11 am
l1ttle_d3vil wrote: its a genuine garrett turbo.
it all depends on the condition of the turbo, IMO going by the pics youve got posted it doesnt look the healthiest with all that gunked up residue in the intake.
they are only a small turbo and they die often on the s13's when the boost is cranked up
evil_si
