so i managed to score myself a pretty cheap blacktop engine,loom and ecu, only really brought it to use the vvt pulley as my one is stuffed,
now i have heard that the black tops are a better engine but what can be taken off them to be used on a silvertop(for some kind of gain), i dont really want to swap the whole engine over as my silvertop has only been rebuilt about 30,xxxkm's ago.
Swap the head and loom and ECU. The Silvertop bottom end is better (conrods) but heavier.
The Blacktop head is better and with the head and the ECU and sensors, you can get rid of the AFM and run some aftermarket trumpets (properly boxed and with a good air feed fo course)
hey thanks for finding that post, well by the sounds of it (and not seeing those dyno results) theres not really that much to be gained by swaping heads, just a little in the upper end.
leave the silvertop bottom... this means you keep using the silvertop cambelt.
Blacktop head.. get it surfaced, light skim .2-.4mm
TRD .8mm heady
Blacktop TB's, headers, cams...
wouldnt bother with the hassle of blacktop ecu. Silvertop one will run it just make sure you seal the plenum up air tight... the bottom dosnt like to seal.
I ran s/t ecu/loom on my blacktop went well. The only other thing you may want is the blacktop pistons but why bother if you have rebuilt it... the TRD heady and a light skim will get you 11-11.2:1
