Caldina Questions.
Postby snwtoy » Sun Dec 09, 2007 10:45 am
Caldina3SGTE wrote:i wanna get a nice new looking strut brace if any one can point me in the right direction
you know the rear one is built into the cargo blind yeah?
snwtoy
Postby Caldina3SGTE » Sun Dec 09, 2007 12:04 pm
oh yea na didn't no that but won't be getting that one prob get a underbody one thanks for the info tho
Caldina3SGTE
Postby snwtoy » Sun Dec 09, 2007 12:47 pm
Caldina3SGTE wrote:oh yea na didn't no that but won't be getting that one prob get a underbody one thanks for the info tho
Sway bar I think the underbody ones are called. But yeah, leave the cargo blind in at all times if possible :)
snwtoy
Postby Matty104 » Sun Feb 03, 2008 9:10 pm
how do you do a pod filter setup in a caldina? ,
theres the map sensor? going into the factory cold air box, then the other assembly that is bolted to the side of the box and returns to the intercooler or plenum ( only had a quick 5 second look)
but i am able to make up s/s piping at work to replace the main hose , would just like to know how others have done it, pics would be much appreciated,
thanks in advance
matt
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby flygt4 » Sun Feb 03, 2008 9:21 pm
simple answer is to not use a pod filter , you will likely find a decrease in power unless you have proper ducting to feed cold air.
drop in panel filter is the way to go.
flygt4
Postby Matty104 » Sun Feb 03, 2008 9:26 pm
that makes life easy then haha , stainless piping wouldnt be that good of an idea to replace that factory rubber pipe would it, as would hold heat?
'Tron E30 Massif
89 BMW 325sci
Matty104
Postby Bling » Sun Feb 03, 2008 9:28 pm
Matty104 wrote:how do you do a pod filter setup in a caldina? ,
thanks in advance
matt
not sure on caldinas, but on ae111 theres only a temp sensor in the airbox, no map sensor
Postby MasCam » Mon Feb 04, 2008 5:29 pm
Yep temp sensor in the air box
MAP sensor in the intake manifold
MasCam
Postby bbq1988 » Mon Feb 04, 2008 7:49 pm
go and buy a Simota pannel from AL @ Driven
my k&n filter cost me $180ish? made a good improvement tho! made the bypass valve alittle louder tho
Baked, Not Fried.
bbq1988
Postby bubz » Fri Feb 15, 2008 2:46 am
thanks in advance
matt
One hose goes into the factory air box and the other goes into the factory intake hose.I have plumbed back the hose that goes to the air box, back to my aftermarket intake pipe and put a breather around the other(yet to set up a catch can with this).Don't know how to load pics on here or else I can put mine up.
1997 Gtt Caldina Tiptronic
bubz
Postby Warren » Fri Feb 15, 2008 7:44 am
bubz, email me your pics and I'll post them up for you
Mr. T says "Don't do school, stay in milk, and drink your drugs"
Warren
Postby Matty104 » Fri Feb 15, 2008 5:29 pm
pics would be good as, cheers
'Tron E30 Massif
89 BMW 325sci
Matty104
Re: Caldina Questions.
Postby snwtoy » Fri Feb 15, 2008 10:05 pm
bbq1988 wrote:Hey guys, who's done what to their car?
Im looking for any ideas on what to do next :)
I've got neons. Best mod ever.
snwtoy
Postby bubz » Sat Feb 16, 2008 12:06 pm
Matty104 wrote:pics would be good as, cheers
IMG]http://i264.photobucket.com/albums/ii185/bubzee7/Image343.jpg[/IMG]
IMG]http://i264.photobucket.com/albums/ii185/bubzee7/Image349.jpg[/IMG]
IMG]http://i264.photobucket.com/albums/ii185/bubzee7/Image352.jpg[/IMG]
bubz
Postby gleem » Sat Feb 16, 2008 11:07 pm
nice bubz very similar to how my set ups going to be, what size is that intercooler piping?
gleem
Postby doin donuts » Sat Feb 16, 2008 11:51 pm
i know this isnt really along the same lines as what you are all talking bout but just wanting to know if anyone here with a gtt has any problems with towing things/ not power wise but mechanical, my wife has a gtt and we want to get a tow bar, what would i expect to pay for that? thanks heaps
4agze ae86 trueno...let the fun begin!!
doin donuts
Postby WCKWGN » Sun Feb 17, 2008 11:41 am
there was a tow bar for the caldina on trademe a couple of months back. i think they had it at $250 odd . maybe try wreckers to get ahold of one. As i under stand they are the same tow bar from the g model through to gtt so i think they would be sourcable enough off a stacked ride.
WCKWGN
Postby bubz » Sun Feb 17, 2008 12:52 pm
gleem wrote:nice bubz very similar to how my set ups going to be, what size is that intercooler piping?
2.5 inch,all universal piping.
bubz
Postby gleem » Sun Feb 17, 2008 9:13 pm
oh yeh same as what im getting, where do you get the gasket from that goes to your downpipe off the turbo
gleem
Postby bubz » Sun Feb 17, 2008 9:25 pm
gleem wrote:oh yeh same as what im getting, where do you get the gasket from that goes to your downpipe off the turbo
The Downpipe flange and Gasket both came with my turbo.It is the standard T3/T4 five bolt flange.Have a look on ebay,there's heaps,some with manifold weld flange as well.Bought mine from ebay.
bubz
