ST205 Suspention
ST205 Suspention
Postby NZVengeance » Tue Feb 19, 2008 9:58 am
does anyone know of a cost effective JDM brand of suspension for a st205
also has anyone converted these to non superstrut and used tradition McPherson's struts?
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
Albert Einstein
He who dies with the most Toys wins!!
NZVengeance
Postby gleem » Tue Feb 19, 2008 12:07 pm
is the st205 same as a st215?
gleem
Postby NZVengeance » Tue Feb 19, 2008 12:45 pm
i wouldn't know. quite possibly different cause the st215 is a wagon.
Albert Einstein
NZVengeance
Postby barryogen » Tue Feb 19, 2008 12:59 pm
ST205 is a Celica
ST215 is a Caldina
I would say that there will be some serious differences... as for what suspension there is for the ST205, check out that link you were sent to yesterday...
http://gtfour.supras.org.nz/
I'm pretty sure there was info in there about suspension, and also links to other forums where you can read what others are doing.
barryogen
2ZZ Guru in training
Postby Jdawg » Tue Feb 19, 2008 2:55 pm
I think Red Mist has, check his project thread
Jdawg
Postby Infinite » Tue Feb 19, 2008 4:09 pm
yes u can convert superstrut to oridinary susp but u cant convert ordinary to super strut
Lots
Infinite
Postby Dell'Orto » Tue Feb 19, 2008 4:57 pm
D2 do a coilover kit for them.
Postby AJz » Tue Feb 19, 2008 5:11 pm
Dell'Orto wrote:D2 do a coilover kit for them.
shudder
*trys to find picture of Silvia with snapped d2 coilovers....*
I had vtax :(
AJz
Postby Dell'Orto » Tue Feb 19, 2008 5:16 pm
Probably ok for a road car, I know of several people with them in road cars who've had no issues. Drifting is a great way to totally destroy a car :lol:
Postby RedMist » Tue Feb 19, 2008 5:55 pm
I swapped out the arms, suspension, hubs, brakes for ST204 non superstrut components. I have no idea as to wither or not it will work as of yet as I haven't had the car aligned. However the arms bolt straight up, the hubs and suspension bolt straight in. Do note that you will loose those large brakes and calipers unless you can mate the rotor to the hub and remount the caliper. In my case I had to loose both anyway as the caliper wouldnt clear 15 inch rally tyres.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby Anth_555 » Tue Feb 19, 2008 6:13 pm
is it beter to go to McPherson's struts?
-1984 Trueno AE85
-1993 Surf LN130
Anth_555
Postby touge rolla » Tue Feb 19, 2008 6:19 pm
If you're considering getting D2's don't, get BC's instead, infinitely better product at only a slightly higher price
touge rolla
Postby Trls250s » Tue Feb 19, 2008 8:45 pm
Why would you swap out the superstrut system for st204 stuff?
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby RedMist » Tue Feb 19, 2008 9:02 pm
Trls250s wrote:Why would you swap out the superstrut system for st204 stuff?
Its a rally car. Superstrut was originally designed for rallying but they found replacing all the joints every stage rather tedious. So all the rally ST205's ran McPherson strut. The ST204 stuff plugs straight up, as I guess would the ST202. Dont worry, I have replaced the struts with Bilstien's and I'm currently attempting to turn down the disks and adapt the 4 pots to the 15 inch rally rims.
RedMist
Postby sergei » Tue Feb 19, 2008 10:01 pm
if it is a road car, replace super strut bits with new (all 4 bits will cost you under $800), and that will last you another 100k+. I just did on mine and the stuff on it was warrantable when I replaced it, it made huge difference, the car feels more solid, suspension rattle gone.
Postby IH8TEC » Tue Feb 19, 2008 10:20 pm
you had a look on DBA website, through all the catalouges and see if there is a factory disc you can fit with a suitable offset adn size? i managed to, and i wouldnt' be suprised if you could, just a thought
Postby Prymal » Wed Feb 20, 2008 10:22 pm
TRD make adjustables , and Coil overs - Both tried and tested on many St205's here in Auckland including my own
Tein make St205 Coil overs , Very VERY expensive though ..
Bilstien make a insert you can modify the struts with , i believe this is what Richard runs in his blue group A
Koni rear shocks are the same as St185 , in fact so is 98% of the rear end. I rewn Koni adjustables in my St185 in oz - loved them ..
D2 do make a coil over , i sell them thru work , wouldnt touch them ..
Stock Struts work just fine for a road car , Seen good results on garys old car ( now franks , which is also had KYB Adjustables , TRD adjustables and now TRD coil overs ) with King springs used in cnjuntionn with them
C-one make coil overs
KYB make adjustable struts , but are Ex japan only via greenline racing
Redmists car is a special case being a rallycar , if his setup works that would be kind a cool as an alternative
neal bates motorsport ( last local campaingner of the Group A WRC St205 ) i believe has the bits also to to the mcpherson strut swap in from old toyota tooling ..
I believe they use the same pieces even up until now on their ARC cars , and personal workshop cars ..
Hows that for a slab of info for you !
And i didnt even have to search google once !
Prymal
Users browsing this forum: No registered users and 55 guests
