hi all, this one should be pretty simple, how do you reset the factory ecu and how do you turn off the factory boost controller.
cedwards wrote:From what I understand you will sit nicely on 8 pounds after removing boost controller,, Surely fivebob if it is boosting higher with no controller installed there is actuator problems (sticking) or inadequate wastegate flow.
