4agte and crank pressure?
Postby escortman » Wed Mar 05, 2008 10:56 pm
in my 4agte i just put a 2lt catch can and i seem to have a lot of smoke coming out still, why is this? Robin suggested steel wool but i cnt really get it in there, any other solutions?
matt
4x4 toyota blizzard offroader
escortman
Postby l1ttle_d3vil » Thu Mar 06, 2008 8:12 am
how many breathers have you got on the rocker covers?
Postby Crampy » Thu Mar 06, 2008 6:59 pm
You need some sort of baffle to catch the oil vapour and condense the oil back to a liquid, that's why I suggested steel wool. I have heard of a few guys using that with good results.
Dunno what else you could try.
Crampy
Postby escortman » Thu Mar 06, 2008 10:28 pm
l1ttle_d3vil wrote:how many breathers have you got on the rocker covers?
1 on each
escortman
Crampy wrote:You need some sort of baffle to catch the oil vapour and condense the oil back to a liquid, that's why I suggested steel wool. I have heard of a few guys using that with good results.
yeh im going to try that on weekend just ram heaps into the filter i guess all i can do with that cuz tops all seald etc
escortman
Postby Crampy » Thu Mar 06, 2008 11:20 pm
The problem is if you block the filter up too much then it wont let enough air out and you'll run into problems again with over pressurising the crank case. It needs to have proper baffling either in the breather or in the cam cover itself.
What's everyone else using? Is there any difference between the breathers on the 4AGZE cam cover and just the normal 4AGE one?
Crampy
Postby escortman » Thu Mar 06, 2008 11:28 pm
hmm didnt think about that
il check to see if there is any differnce on weekend
escortman
Postby RedMist » Fri Mar 07, 2008 8:34 am
I think you are looking at the wrong end of the problem. It appears that you are attempting to condense the vapor rather than finding out where the vapor is coming from.
If you are getting a steady stream of air flowing out of the vents then you have some serious blowby. I would be checking compression.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby rollaholic » Fri Mar 07, 2008 6:12 pm
leakdown test ftw if it is blowby!
Postby escortman » Sat Mar 08, 2008 1:22 am
i did a compression test couple weeks ago and was 205, 195, 195, 205
could that mean something? its really high for turbo i believe ?
will do a leak down on the weekend and go see my engine builder
escortman
Postby escortman » Tue Mar 11, 2008 7:33 pm
will try get a leak down test done on the weekend
escortman
