Wanted: Pics of peoples caldina intake's
Postby bbq1988 » Fri Mar 07, 2008 9:22 am
Hey guys, anyone keen to post some pic's of how their intakes are setup? i am looking at modifying the standard airbox by adding more ducting. im just after ideas :)
Harley
Baked, Not Fried.
bbq1988
Postby gleem » Fri Mar 07, 2008 11:23 am
just got a pod straight off the turbo atm.. would of kept standard airbox but it was too messey with it in there and trying to front mount it.. porb going to try a set up similar to AJ's and get a box round it
gleem
Postby sleepy » Fri Mar 07, 2008 11:33 am
Hi gleem, what did you do with the air temp sensor, did you plumb it back into the piping of your pod intake? or did you just leave it hanging near the pod filter?
sleepy
Postby gleem » Fri Mar 07, 2008 3:16 pm
its just hanging atm. havent given it too much thought trying to fix rattling noises atm.. whats the idea thing to do with it?
gleem
Postby sleepy » Fri Mar 07, 2008 5:28 pm
gleem wrote:its just hanging atm. havent given it too much thought trying to fix rattling noises atm.. whats the idea thing to do with it?
Not sure to be honest. I was thinking of plumbing mine back into the intake (this is when I do go down the cold airbox road). I think it should be alrite if the sensor is in the cold air box near the air filter too.
Sorry Harley for taking the thread off topic.
sleepy
Postby 99gtt » Fri Mar 07, 2008 6:30 pm
Image[/img]
SOON TO BE 500 HP
99gtt
Postby gleem » Sun Mar 09, 2008 8:41 pm
got a bigger photo james? can't see too much with that one >_<
gleem
Postby 99gtt » Sun Mar 09, 2008 8:55 pm
na i havent that photo was on my old phone thats why it is crappy . That is my old set up worked pretty well having the filter in the scoop
SOON TO BE 500 HP
99gtt
Postby strx7 » Sun Mar 09, 2008 9:41 pm
sleepy wrote:Hi gleem, what did you do with the air temp sensor, did you plumb it back into the piping of your pod intake? or did you just leave it hanging near the pod filter?
the std air temp sensor for the efi system is located in the plemum chamber of the inlet manifold, has a 3 pin plug from memory
Postby sleepy » Sun Mar 09, 2008 10:32 pm
ahh then what is the 2 wire plug thingy in the factory airbox? It's also a temp sense right?
sleepy
