matt dunn wrote:The 20V 4age's had a 3 wire ISC valve that is remote mounted.
It bolts to the head just under the ITB's.
You may remember it,
or even have one among your bits and pieces.
I have a few if you get stuck.
Matt
RedMist wrote: Do you use one Matt? Just wondered if they take boost pressure or leak.
gmacrae wrote:There's no need for an iacv, esp in a racecar. Remove it and make your own idle control valve of some sort (ball valve works good on my silvertop). Starts perfect cold and idles at 600ish, 900 warm, could go lower no prob.
gmacrae wrote:
Are you worried about an IACV leaking under boost? Cant you just take its air supply post-compressor? so under boost, pressure either side of it is more equal?
sergei wrote:back to original post, you say you cannot use stock ST205 ICSV, why?
As far as I know the construction and functionality is similar to 20V one...
If everything fails you could get a generic BOSCH Idle control valve, which could be PWM or crude ON/OFF sort of thing. These things are humongous and can flow a lot.
matt dunn wrote:We do bosch thru work if you want IAT sensors and stuff.
Do you have part numbers or want options?
MasCam wrote:Yeah was just thinking that it may be easier and more reliable to use a separate air feed with a solenoid valve in it than making a setup to cock the throttles??
Also I can't quite get my head around how you run antilag and get good engine braking, wouldn't you have to inject air into the exhaust manifold for that??
