in most cases, it isn't the noise that is the issue. as it is part of the exhaust, then it must exit the vehicle at least behind the driver. essentially, a vented wastegate is an exhaust leak and therefore must be repaired as such.Guss wrote:like sergie has pointed out in past a coke can sized resonator on the wastegate would fulfill these requirements.
a WOf inspector that knows anything about cars will know by inspecting the piping whether or not it vents, as the majority of cars with them are EAST_WEST mounted engines, and the piping is usually done quite obviously.method wrote:People will always have gates that vent, its quite hard to see if they do or they dont unless you hear them.
it might be hard to spot, but officers would becoming aware of what to look for.method wrote: Oh would be real easy to spot on a hoist. But on the ground, if a officer pulls you up or what ever it could be quite hard to spot.
im sure that when push comes to shove,not giving your mates illegal WOF's will be more beneficial than having your WOF issuing authority removed and being fined heavily. a real mate wouldn't take a car to another mate for a 'soft' WOF if he knew the consequences.method wrote:A lot of car enthusiasts have friends that work at garages and issue wofs.
I want to make sure my car is safe. Suspention, brakes, wheel bearings, structural rust etc.
narlystarly wrote:On another note, I saw an evo 3 with the screamer pipe routed all the way to back the rear of the car where it sat alongside his muffler.
Is the issue with the noise or is it exhaust exiting foward of rear most door etc?
not_paul_from_waiheke wrote:maybe this is a good time to ask, someone mentioned a while ago that it is legal to vent the w/g in front of the drivers wheel, out the side of the car..?
deaf_rattle wrote:im all for it.
people that drive so their screamer pipes can be heard in carparks are dicks.
method wrote:deaf_rattle wrote:im all for it.
Anyone who boosts through carparks are dicks, screamer or no screamer
smithers wrote:I dont really see them as being harmfull.
Sure having exhaust gas leaking in front of the firewall can get into the cabin, but how often are you driving at full boost? Wouldnt be for more then 1minute. Stopping in a traffic jam with a car infront of you would be more dangerous, or beside a big truck with its exhaust dumping straight into your window because youve lowered your car to that height!
And in an mr2, that would be perfectly legal by the sounds of things to have some sort of muffler on the screamer, since its behind the last opening window anyway.
