Need some advice......
Postby pac » Mon Feb 25, 2008 1:12 pm
I've just bought a 84-87 Ae82 which I intend to use as a track car and club car and don't what it be turbo or supercharged as I Don't want to enter that class of race yet
it currently has a bluetop 16v in it which has blown oil rings
(1) I'd like to Know what sort of Power I can get out of the engine if I
rebuilt it
I have budget from $4000 this is just for the engine
(2) I've been told that there is something different between Redtop and bluetop
(3) And what Sort power could i get out of a blacktop 20v
thanks
pete
pac
Postby bluemaumau » Mon Feb 25, 2008 1:33 pm
buy a blacktop and put silvertop rods in it, will be less than 4k id say, would be a mean track car
Postby Trls250s » Mon Feb 25, 2008 2:08 pm
bluemaumau wrote:buy a blacktop and put silvertop rods in it, will be less than 4k id say, would be a mean track car
Agreed
OR Build yourself a 7age. 7afe block/crank and conrods, silvertop pistons, redtop head, silvertop ITB's. You can get all these parts cheaply from trademe ($60 for pistons, 7afe engine for $300 or so, $200 for ITB's) then get yourself a megasquirt from america or run a redtop ecu and dizzy.
Can do it cheaply/do it yourself and you will have a 1800cc that goes like hell that will bolt unmodified into your ae82.
edit:
didnt really answer your questions haha.
Bluetop has 88kw standard and redtop has 100kw. Redtop has slightly higher compression and smaller intake ports. If you lok around on here you will find heaps of information regarding the differences in these engines.
2 1/4" exhaust is a good upgrade, if your going to keep it 16v use the blacktop extractors. The usual like pod filter/cold air box will give you some more power, and just rebuilding the engine with new bearings and stuff will really improve the responsiveness of the engine.
But if you have $4k to spare, id buy a new engine. Rebuild it then slot it in there.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby JustinSpiderholden » Mon Feb 25, 2008 2:13 pm
Agreed
dont bother with 7age, for 4g, better off to jsut get blacktop, with silvertop rods, spend spare coin on head work cams :P
200cc is $&#$% all differnce, imo 7age's are only worth the effort if you are going to build a big power turbo motor
another intresting conversion would be a 2zz, and six speed box from the latest modle celica, or corolla
JustinSpiderholden
Postby ee904age » Mon Feb 25, 2008 6:13 pm
JustinSpiderholden wrote:another intresting conversion would be a 2zz, and six speed box from the latest modle celica, or corolla
OR even better, from a TRS race car :twisted:
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby RedMist » Mon Feb 25, 2008 7:09 pm
You'll be considerably better off keeping within the 1600cc bracket. The regulations will ensure you are placed with cars you can be somewhat compeditive with. 1800cc... you may, dependant on events, be thrown in with all the big NA vehicles.
Blacktop, silvertop rods, and a set of good shocks. Then if the budget copes, brakes then possibly a bit more power with large cams, vernier pulleys.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby rollaholic » Mon Feb 25, 2008 8:33 pm
RedMist wrote:You'll be considerably better off keeping within the 1600cc bracket. The regulations will ensure you are placed with cars you can be somewhat compeditive with. 1800cc... you may, dependant on events, be thrown in with all the big NA vehicles.
win
Postby pac » Mon Feb 25, 2008 8:37 pm
I looking at keeping it 1600cc as I'd to be close to winning
I thinking going to put new ring in the bluetop for setting up the car and a little track use untill I can get a blacktop 20v which I rebuild
pac
Postby Bling » Mon Feb 25, 2008 9:15 pm
pac wrote:I looking at keeping it 1600cc as I'd to be close to winning
don't throw good money down the drain on that bluetop (rings etc)
if you don't have the coin yet, wait. No point spending money on an engine thats going to be replaced.
Postby tsoob » Mon Feb 25, 2008 11:19 pm
get more money then turbo it
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby pac » Tue Mar 18, 2008 7:03 am
bump
pac
Postby TRD Man » Tue Mar 18, 2008 7:54 am
pac, you've got the right idea. Get the motor you've got running and get out on the track.
Get the car set up right with brakes & handling. Learn some race craft.
And when you are at maximum attack everywhere on the circuit and are starting to get some good results, then look at the engine.
I don't entirely disagree with BZGBling's comment however the cheapest equipment you'll ever buy is the stuff you already own. Work with it until there is a need to change.
You'll find that by the time you've done those things mentioned above you'll have saved back the amount you spent on the rebuild and you'll be a better driver too.
TRD Man
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
