fivebob wrote:Anyone noting that their engine temperature gauge is running lower needs to check out their overall cooling system efficiency. A thermostatically controlled cooling system of sufficient capacity should not be affected by this mod
RedMist wrote:It would certainly be interesting to measure the pressure differentiation between the firewall and windscreen.
I suspect that in the case of the ST205 the firewally is greater. Early WRC cars had problems at high speed with the back edge of the bonnet bowing upwards. Hence the idiotic addition of a wing spoiler to the trailing edge of the WRC bonnet. I suspect that all this spoiler does is act as an additional bonnet brace, but if you are having problems with high pressure differential underbonnet, why not just vent it? Cut the trailing edge back 1cm or so? Vent the pressure underbody? Or through the side guards? There must have been a million ways for TTE to have corrected this issue rather than the band aid that is the bonnet spoiler.
