Stuck bolts
Stuck bolts
Postby MR2SIK » Thu Mar 27, 2008 7:39 pm
In the process of removing my downpipe to get it fixed, a couple of the bolts holding it to the turbo are pretty stuck.
Anyone got any tricks to how to remove them? I sprayed crc on them and tried... So I sprayed alot of crc on them and am gongi to have another crack at it later on. Just wondering if anyone has any easy fixes :lol:
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Dell'Orto » Thu Mar 27, 2008 8:13 pm
Loctite Freeze and Release, works wonders.
Postby MR2SIK » Thu Mar 27, 2008 8:18 pm
Repco?
I'm a cheap cnut so it better not be pricey :lol:
MR2SIK
Postby Dell'Orto » Thu Mar 27, 2008 8:21 pm
Yeah, repco should stock it. I think from memory its like $20 retail, and you'll wish you'd bought it before you started.
Postby xsspeed » Thu Mar 27, 2008 10:30 pm
have you got a six face socket as opposed to a triple square
Postby IH8TEC » Thu Mar 27, 2008 10:33 pm
try give them a short sharp pull, to try and crack them too
Postby bluemaumau » Thu Mar 27, 2008 10:44 pm
crc penetrate
8)
Postby Mr Revhead » Thu Mar 27, 2008 10:51 pm
bluemaumau wrote:crc penetrate
8)
oh baby
are they rusted?
wire brush rust off (watch the eyes) the spray with rost off then brush again
then use that freeze stuff.
then have a can of harden the f**k up and try again.
bloody hairdressers trying to work on their cars
Postby Al » Fri Mar 28, 2008 12:43 am
They shouldn't have rusted up that quick :?
I'll see if the old man can get your downpipe welded up for nix.
Al
Postby cat007 » Fri Mar 28, 2008 8:58 am
If they're really tight, shock treatment - i.e. hit them with a BIG hammer, fast and sharp.
But being on a turbo, probably not a good idea :P
Postby darkwolf » Fri Mar 28, 2008 10:25 am
Cold Chisel.
Nuff said :)
Brute force and ignorance always prevails.
Failure comes from too little brute force, or too little ignorance.
darkwolf
Postby Mr Revhead » Fri Mar 28, 2008 10:36 am
oh yeah go barnsy!
you must have good music on whilst working on cars.
it inspires you!!
:lol:
Postby Crucible » Fri Mar 28, 2008 12:32 pm
just use 6 point sockets, less likely to shift on the head than 12 points.
if all else fails heat is your friend.
Crucible
Real Life Mechanic
Postby Silent Knight » Fri Mar 28, 2008 3:18 pm
Angle Grinder. 8)
Silent Knight
Postby MRDRFT » Fri Mar 28, 2008 5:56 pm
Silent Knight wrote:Angle Grinder. 8)
AMEN to that man
1992 toyota supra 1JZ power
210kw atw on 12psi
1999 nissan silvia drift car,
223kw atw on 12psi
MRDRFT
Postby Mike- » Fri Mar 28, 2008 6:10 pm
big c**t of a power bar + foot if theres enough room, otherwise what sk said
Mike-
Postby MR2SIK » Fri Mar 28, 2008 6:43 pm
Casulties so far....
One Factory Toyota 14mm Spanner
One El Cheapo 14mm Spanner
One Decent 6 Point Socket
One El Cheapo Socket
Missing in Action:
decent sized chunk out of my left Forearm :lol:
My Patience..
God i love cars :lol: :lol: :lol:
MR2SIK
Postby IH8TEC » Fri Mar 28, 2008 6:45 pm
haha, :lol:
Postby MR2SIK » Fri Mar 28, 2008 6:50 pm
How good are powerbuilt tools? Thinking I may buy a spanner tomorrow, but at $30 each it better not bend out of shape too easily :lol:
MR2SIK
Postby IH8TEC » Fri Mar 28, 2008 6:55 pm
are you giving them a sudden whack? or are you gradually putting more pressure on,
powerbuilt has lifetime warranty correct?
