rally4life wrote:my understanding of VVT on the silver top is that there is a solanoid that opens at a 3500-4000 rpm under half to full throtle that let oil into a canaster on the end of the cam which with incressed mass will retard the cam timing. but with what i am reading this has nothing to do with rpm but more to do with throtle position
Is this right???
Mr Revhead wrote:you probably did
iv also seen ppl post about semi forged pistons and 400hp ct26 turbos
neo wrote:but not when you take your foot off the gas to change gear and the tps angle is less than xx% load and vvt goes bye bye...
