C5x gearboxes
C5x gearboxes
Postby xsspeed » Mon Mar 31, 2008 5:16 pm
hey guys did a search on the diffrences between c52 and c56 gearboxes.
I have a silvertop motor, and was tryna find out what i have, is the only difference the 3rd and 4th gear ratios? some posts said this and others said that there is a difference in the backing plates?
when did the c56 come in, was it with the 'later' model silvertop that i have heard about?
based on personal preference/experience what is the best box to bolt up to a n/a 4age?
think i also read that the c56 has lsd, or is that rubbish?
and finally what is the 6spd from the likes of a bz carib? (or is that the c56) and is it a worthwhile buy?
cheers guys
Postby Bling » Mon Mar 31, 2008 5:26 pm
I can't answer it all, but.
c56 can be open and lsd afaik
6 speed seem to be weaker than the 5 speeds and expensive to rebuild, so not worth the wank factor / stupid money people want for them
Postby xsspeed » Mon Mar 31, 2008 6:34 pm
thanks bud, yeah was wondering what the deal was with the 6spd, people asking heaps for them on TM, dont want wank factor want something that drives well, i'll have enough wank with the silvertop in the ee80 lol
Postby AceSniper » Mon Mar 31, 2008 8:17 pm
c56 in later ae101's and 5speed 20v ae111's
BZV c56 has a lsd, you may find some others with them? but not that common, the 6speed lsd will fit the 5speed... all bzr box's = LSD
the ae101 c52 is the same as the c56 asides from 3rd and 4th... bit shorter help keeping in the power.
AceSniper
Postby pc » Tue Apr 01, 2008 11:22 am
I have a few C50's and I think 3rd is too high. So a lower 3rd would probably be a good idea.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby neo » Tue Apr 01, 2008 11:46 pm
http://ae101.tappsville.com/chassis/ I have the ratios here.
Seems everyone whos had a 6sp had broken them.
I myself went for a C56 as the ratios in 3/4th were 'just' to short for me on the track
neo
Postby xsspeed » Thu Apr 03, 2008 10:57 pm
can i figure the ratios while its still on the block or is it a take it off kind of job
Postby Elmendorf » Fri Apr 04, 2008 10:21 am
I had a donor C56 out of a AE111 5 speed that had a factory LSD in it. Use the 3rd and 4th and final drive in my C52 box found it better for the track but on open road driving I need a 6th gear.
Elmendorf
