turbo rebuild
turbo rebuild
Postby escortman » Mon Mar 31, 2008 6:50 pm
just after some places in west auckland to do the seals on my td05 16g
4x4 toyota blizzard offroader
escortman
Postby deaf_rattle » Mon Mar 31, 2008 7:00 pm
just take it to alltech, wairau road.
not far to go. good guys
Postby escortman » Mon Mar 31, 2008 7:04 pm
o yeh any idea on cost?
escortman
Postby cat007 » Mon Mar 31, 2008 7:31 pm
Depends what's actually at fault. Are you sure its the rings?
If they are worn bad enough they could have damaged the turbine shaft - and that can be pricey.
For a basic tear down, clean, rings replace and assemble, you're probably looking around $250ish - or less
I don't work for them so I don't know their prices.
Give them a call and find out - ask for Chris - he's good.
Postby escortman » Mon Mar 31, 2008 7:45 pm
thers no play in the shaft but smokes like goat on crack
only started last week but havnt really drivin it
escortman
Postby deaf_rattle » Mon Mar 31, 2008 8:05 pm
escortman wrote:thers no play in the shaft but smokes like goat on crack
haha, it looked more black than anything when i was behind you.
Postby escortman » Mon Mar 31, 2008 8:11 pm
o yeh that was wen it was fine just overfueling now sits smoking blue
escortman
Postby tsoob » Mon Mar 31, 2008 9:55 pm
i just rebuilt 2x td03's at $600 each retail thru a1 turbos is silverdale for a customer of mine.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby cat007 » Mon Mar 31, 2008 10:08 pm
tsoob wrote:i just rebuilt 2x td03's at $600 each retail thru a1 turbos is silverdale for a customer of mine.
But what was included in the "rebuild"?
Postby tsoob » Mon Mar 31, 2008 10:17 pm
i have not got them back yet, will know tomorrow when i recieve, would thinkg its seals and bearings but not 100%
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby solitaire » Mon Mar 31, 2008 11:03 pm
escortman wrote:o yeh that was wen it was fine just overfueling now sits smoking blue
Isnt blue smoke oil burnt during combustion rather than leaking out the turbo and burning up? (question... im a bit of a noob)
AE92, KZJ120, KDJ120
solitaire
Postby method » Mon Mar 31, 2008 11:40 pm
usually turbo smoke will be white.
PICS UPDATED DAILY
method
Postby escortman » Tue Apr 01, 2008 6:32 am
yeh but i think it may be comig out the front housing as well which means would be going thru engine
will be pulling head and turbo off tonight to check anyway
escortman
Postby Stu- » Tue Apr 01, 2008 8:29 am
Usually a full rebuild will be a complete strip down, complete clean, new seals and bearings, assembly, balance, warrenty etc. Damian @ A1 Turbos is good - would recommend him.
Project Thread
Stu-
Postby cat007 » Tue Apr 01, 2008 10:56 am
rings - RINGS people
Not "seals"
:lol: :lol:
Postby ~SlideWays~ » Tue Apr 01, 2008 11:43 am
When I put my new 4agze longblock in and changed turbo and bigger injectors mine ran majorly rich due to the bigger injectors and was tuned for standard ones.
It had black smoke and sometimes very blue. After tuning it has no probs at all.
Are you sure the turbo is stuffed?
~SlideWays~
Postby escortman » Tue Apr 01, 2008 8:06 pm
~SlideWays~ wrote:When I put my new 4agze longblock in and changed turbo and bigger injectors mine ran majorly rich due to the bigger injectors and was tuned for standard ones.
thats wat mine ran like
but now its smokes at idle but not all the time but quite a lot of smoke
wont get a chance to pull head and turbo off till weekend now mostly due im lazy and cbfd hahaha
escortman
Postby cat007 » Tue Apr 01, 2008 9:15 pm
If its too rich at idle you'll bore wash and you'll burn oil like there's no tomorrow
Postby escortman » Tue Apr 01, 2008 9:21 pm
o ic is it repairable or have i fukd my block ?
i think its lik 14 at idle
escortman
Postby escortman » Fri Apr 04, 2008 6:49 pm
good news redid my oil feed now has a restrictor in it and no smoke what so ever probably wont last to long but fixed for now cheers for all the help guys
escortman
Users browsing this forum: Google [Bot] and 57 guests
