z|gen wrote:you would be better doing that, but anyone with half a brain and knows 4wds, height isnt always a good thing, best thing is to get diffs off the ground, not the body lol
Elmo wrote:z|gen wrote:you would be better doing that, but anyone with half a brain and knows 4wds, height isnt always a good thing, best thing is to get diffs off the ground, not the body lol
Anyone with half a brain knows that bodies fill with water, so lifting chassis and body is a fantastic idea. Sure, body height is an issue for sidling a hill etc, but thats the wrong place to be driving anyway.
Getting diffs off the ground has and always will be a major issue, but more so is body clearance when it comes to sills and dropping in and out of rivers, holes and over rocks etc.
As for going to IFS, what? Are you stupid? Do you know ANYTHING about 4x4's? Independant suspension is NOT the way to go, it bites the big fat hairy kumera.
strx7 wrote:Decent IFS ie: custom made, no where near factory. is actually better than beam axle but you need to spend HUGE $$$ making it and getting it set up right. the problem with beam axle is the grip & angle on one front wheel is determined by what the other one is doing. Good IFS is totally independant hence the name
Elmo wrote:Im yet to see a serious 4x4 that has indipendant on it. Ive known MANY people who have converted there IFS trucks to solid axles for the simple fact of better reliability, and travel/articlulation
