4age hybrid ARP headstud issues
Postby bluemaumau » Tue Apr 08, 2008 12:48 am
specs:
20v silvertop block
smallport 16v head
ARP head studs
TRD 0.8mm metal HG
4AGZE CAS
ive run into this issue im hoping some knowledgable people may be able to help me with.
as i slide the CAS into its port it is just fouling on the head stud below it.
here are some pictures:
sorry about the image size i cant get the resize thingy to work
the head is torqued down to 60ft/lbs and i have used the ARP moly lube.
ive sort of run out of ideas, so any help or suggestions to why this is occuring would be greatly received.
hopefully its something simple
Postby ChaosAD » Tue Apr 08, 2008 6:55 pm
There was a thread about this not long ago. Forget how they fixed it but a search should bring it up
ChaosAD
Postby QikStarlie » Tue Apr 08, 2008 7:02 pm
yeh. the bolts were upside down in last thread i think. but look to be right way in those pics.
i'd say the bolts have not been wound down into the block enough, before you put head on and torqued up.
QikStarlie
Postby bluemaumau » Tue Apr 08, 2008 9:27 pm
yea wrong way last time. :oops: :lol:
im sure they are right down. i put a ruler on top of them and all 4 exhaust studs are level, and the "problem" stud was atleast 6-8mm lower. :?
so im guessing it is supposed to be sitting lower than the other 4.
Postby QikStarlie » Tue Apr 08, 2008 10:10 pm
dont remember mine being lower, but could have been. if it can't go down futher, you'l just have to pull the stud out and trim the end off.
QikStarlie
Postby 4agtepwr » Tue Apr 08, 2008 10:13 pm
mine was exactly the same, I shortend the cas shaft so it would clear
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby Trls250s » Tue Apr 08, 2008 11:43 pm
off topic a bit, but are you runing 20v pistons with 16 head? If so tell me how that goes as i was thinking of doing the same.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby IH8TEC » Tue Apr 08, 2008 11:53 pm
this is weird, cause i never had a problem
Postby Lloyd » Tue Apr 08, 2008 11:55 pm
You can always grind something off somewhere
Postby bluemaumau » Wed Apr 09, 2008 12:16 am
what to grind? CAS or stud?
nope ae101 oversize gze pistons.
Postby TRD_ZERO » Wed Apr 09, 2008 10:19 am
ID say grind the cas as 4agtepwr said i wouldnt want to hinder the structural integrity of the stud.
TRD_ZERO
Postby bluemaumau » Wed Apr 09, 2008 11:01 am
yea i understandd that, but CAS's are expensive and spinning pretty fast, wouldnt want to unbalance it
Postby slighty_sykotic » Wed Apr 09, 2008 11:17 am
I really doubt you would, just grind it flat across, then you can't hurt it.
They are only spinning at up to half engine rpm aswell?
slighty_sykotic
Postby bluemaumau » Wed Apr 09, 2008 12:35 pm
true, wouldnt be too bad if i just cut a angled fillet of the stud tho would it?
thanks for everyones help btw
Postby slighty_sykotic » Wed Apr 09, 2008 12:45 pm
Not until you tried to undone it in a years time, after it has seized in place...
And the stud cracks across where u weakened it.
slighty_sykotic
Postby bluemaumau » Wed Apr 09, 2008 12:54 pm
true that,
come here CAS! :twisted:
