Caldina how to remove dash
Postby magnazan » Sun Mar 30, 2008 8:27 pm
Well the final fix on my list is to get rid of what sounds like a screw loose in one of the windscreen air vents.
I did some searching on the forum but couldn't find much info on removing the dash. I know there are a few guys who have gutted dinas and just wondering if
A) it's a huge job and i should just turn up the beats to drown the noise out, or
B) it's not that bad and it's only a few screws
or
C) There is some trick to get to the vents without unscrewing everything
Any info would be greatly appreciated :)
magnazan
Postby method » Sun Mar 30, 2008 8:46 pm
I would be interested too.
It seems the whole surround around the stereo going right over the dash is one piece! weird design that looks like it could be a pain in the ass.
PICS UPDATED DAILY
method
Postby Stu- » Mon Mar 31, 2008 8:17 am
If you pop out the top glovebox thing, then carefully start at the top and work down, that surround and the vents pops out relatively easily.
Project Thread
Stu-
Postby gleem » Mon Mar 31, 2008 3:06 pm
yeh you definetly dont need to remove the whole dash, removing the dash is quite a mish
gleem
Postby GTCRSHR » Mon Mar 31, 2008 4:31 pm
have you thought about a vacumme and some flexible hosing to try get it out ?
Nothing to see here ...
GTCRSHR
Postby magnazan » Tue Apr 15, 2008 4:37 pm
I did think about using a vacuum but i think the vents are a little too close to the windscreen to get at properly. I was thinking about creating an electromagnet but i'll give the popping the vents out a go. When it stops raining that is.
magnazan
Postby soopachargen » Tue Apr 15, 2008 8:09 pm
expanding foam in the vents will cure the rattle :twisted:
When in doubt, down and out.
soopachargen
