How powerful is the most powerful 4age/4agze/4agte?
Postby gasman » Wed Apr 16, 2008 1:28 pm
im running 550's on the stock fuel pressure regulator, i have a sard one mounted up and all ready to be plumbed up but andre said it still wont be enough fuel anyway. I was going to push it to 25psi but common sense and safety stopped me on 98.
I will however push it once i save up enough for some bigger injectors and some C16.
The destroked 4age that Bob Norwood is running seems very impressive but i can find any power numbers in that article.
"What can possibly go wrong?"
gasman
Postby IH8TEC » Wed Apr 16, 2008 1:41 pm
there is nothing wrong with 25psi on 98, as long as your tuner is not a munter (pretty sure andre ISN'T), barry tuned his on 98, thats 27psi (has gone to 30psi too) and 70kw more. just make sure you have colder plugs, recommend 8's or even 9's, and gap them right.
it's nothing to do with common sense it's very doable.
by the sounds of it you want well over 300kw somewhere, either go 800's or even 1000's if you wanna try match the power some of the guys are making around the world.
Postby method » Wed Apr 16, 2008 1:56 pm
I've always thought of the 4age as one of the best "bang for buck"' engines. You can get cast turbo manifolds off ebay for $100, put a turbo on and make a fair wack of power for under $1,000
If i were to spend lots of money on a engine to make power i would start with something bigger, like a 2JZ. Unless you want to compete in some sort of CC restricted class or what not.
A F20c turbo would be the shit :D
PICS UPDATED DAILY
method
Postby gasman » Wed Apr 16, 2008 2:50 pm
IH8TEC wrote:there is nothing wrong with 25psi on 98, as long as your tuner is not a munter (pretty sure andre ISN'T), barry tuned his on 98, thats 27psi (has gone to 30psi too) and 70kw more. just make sure you have colder plugs, recommend 8's or even 9's, and gap them right.
its common sense when good quality 98 isn't available everywhere in the south island.
method wrote:I've always thought of the 4age as one of the best "bang for buck"' engines. You can get cast turbo manifolds off ebay for $100, put a turbo on and make a fair wack of power for under $1,000
ive never seen these cast manifolds on ebay before.
gasman
Postby CAMB01 » Wed Apr 16, 2008 3:02 pm
Managed to get 260kw on 20psi but that was with 100% injector duty cycle.
:D
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby cogent » Wed Apr 16, 2008 3:05 pm
just had a look on ebay myself. Cast manifolds for like $60US, and I also found this:
http://cgi.ebay.com/ebaymotors/Toyota-C ... enameZWDVW
Assuming $100US for shipping to nz, thats less than $800NZ for a manifold, turbo, oil lines, gaskets and fittings. crikey.
Obviously it could be a case of get what you pay for, but still.
cogent
Postby tenyearguarantee » Wed Apr 16, 2008 3:44 pm
this is on trade me
TE71 toyota levin race car for sale
4AGE turbo with TRD quad throttle bodies, Big injectors, Custom plenum chamber, Twin coil packs, TO4 Turbo, Tial Wastegate, custom extractors.
Dynoed on the 14th of march with new extracters and made 355 hp at 16psi boost.
http://www.trademe.co.nz/Trade-Me-Motor ... 596929.htm
tenyearguarantee
Postby ~SlideWays~ » Wed Apr 16, 2008 3:47 pm
Thats been on TM for centuries, 355hp ain't bad. Wonder if thats atw or flywheel?
~SlideWays~
Postby JustinSpiderholden » Wed Apr 16, 2008 3:55 pm
Ok
first person in nz, to make more than 300kw with a turbo 4age still 1600cc or less I will buy a box of beers
Chur
The levin on trade me the 355hp is at the wheels was tuned on nz efi's dyno
Oh BTW for the beer the dyno reading cannot be from tricky tune or tourque performance
JustinSpiderholden
Postby IH8TEC » Wed Apr 16, 2008 4:00 pm
there are two people i can tell you straight up,
LOTOY in a ke30? runs low 11's, massively worked head.
and Kent from speedsources cousin has 320kw at the rear wheels in a red dx wagon with gt3040, revs to 10k, and 20psi boost, he mentioned that was without the nitrous too;
both still 1600s
and gasman, you can always turn down the boost :wink: most places close to racing in the would have some good 98 down there too. especially if you go to the effort of taking c16 down with you, but hey, each to there own, alot of people under estimate how much power can be made on 98.
Postby ~SlideWays~ » Wed Apr 16, 2008 4:06 pm
JustinSpiderholden wrote:Ok
Chur
Thats gotta be some good/expensive beer...
EDIT: 355hp atw is just slightly over gasman's new figure... interesting.
~SlideWays~
Postby JustinSpiderholden » Wed Apr 16, 2008 4:29 pm
Chur
Beers r what ever the person choose within reason they must post dyno sheet on forum and have specs and info on car posted as well
JustinSpiderholden
Postby gasman » Wed Apr 16, 2008 4:33 pm
IH8TEC wrote:there are two people i can tell you straight up,
the two main contributing factors imo. very nice numbers.
gasman
Postby method » Wed Apr 16, 2008 6:47 pm
cogent wrote:just had a look on ebay myself. Cast manifolds for like $60US, and I also found this:
Exactly, i never saw that kit but thats definatly good.
It cant be that bad, remember you are putting it non a $100 engine anyway :lol:
PICS UPDATED DAILY
method
Postby flygt4 » Wed Apr 16, 2008 6:57 pm
pretty sure TIMID was well over 300kw, still 1600cc, more like 330kw when it was doing 10.5's.
was basically a standard bottom end with huge turbo and lots and lots of fuel.
flygt4
Postby l1ttle_d3vil » Wed Apr 16, 2008 7:14 pm
30psi 4agte project build - http://www.garagedori.com/forum/viewtop ... f=2&t=2973
$175 cast manifolds on trademe - not sure if the guy is importing more though?
http://www.trademe.co.nz/Browse/Listing ... =147348207
and the turbo package in ebay is on trademe too - no need to import it yourself unless its easy and you can save a bit of $$. http://www.trademe.co.nz/Trade-Me-Motor ... 86.htm?p=3
and the l0toy is running nos too isnt it?
there was a guy was building a ke25 drag car, his aim was 350kw atw and a 10s car...he ran out of money before he finished it though. would've been interesting to see in an 800kg car though :lol:
Postby Bling » Wed Apr 16, 2008 8:37 pm
l1ttle_d3vil wrote:$175 cast manifolds on trademe - not sure if the guy is importing more though?
http://home.iprimus.com.au/jverban/ then go to parts... incase anyone wants one anyways :P
Postby Bazda » Wed Apr 16, 2008 9:33 pm
Gasman - 98 will be fine using 25psi, I did it safetly on mine easily with heat range 8 plugs. I was running 18 deg advance as well. Combustion chamber of the blacktop head is awesome!!
Oh wait.. what compression are u running?
Any of those 4agtes using 30psi 1600 etc, id like to see them out on a circuit and see how long they last :D.
Postby Bazda » Wed Apr 16, 2008 9:35 pm
gasman wrote:im running 550's on the stock fuel pressure regulator, i have a sard one mounted up and all ready to be plumbed up but andre said it still wont be enough fuel anyway. I was going to push it to 25psi but common sense and safety stopped me on 98.
550cc and ur running that much power... hmm I would thing ur running ur injectors at 90%ish
Postby IH8TEC » Wed Apr 16, 2008 9:41 pm
only running stock fuel pressure though
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
