HT leads for link ecu
Postby l1ttle_d3vil » Mon Apr 21, 2008 8:37 pm
Link G3 Manual wrote:Unsuppressed H.T. leads act as aerials and radiate very powerful interference signals. ALL applications must use suppression leads, preferably resistance type rather than spiral wound or inductive. Typically these vary from 1000 ohms to 5000 ohms depending on lead length. NEVER use plain wire leads.
I've got these Eagle HT leads on my 4age, will they be sweet to use with a Link G3? Just not too sure as it says "Spiral Core" on the leads. Does this rule them out, or is measuring the resistance a definitive way of working out if they will be usable?
Postby Burning Angel » Mon Apr 21, 2008 9:03 pm
they will be fine to use as they are the inductive/spiral style.
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby Lloyd » Mon Apr 21, 2008 11:04 pm
Pretty much anything available that isn't solid core stuff should be fine
