Hotchkiss sway bars in NZ
Postby barryogen » Wed Apr 23, 2008 6:18 pm
Anyone know a source for them? google suggested no-one.
Specifically a rear bar for a 2001 Altezza RS200Z
barryogen
2ZZ Guru in training
Postby tsoob » Wed Apr 23, 2008 6:40 pm
can get whiteline??
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Sideros » Wed Apr 23, 2008 6:57 pm
Go to your local Ripco, take lube with you and get ready to bend over... (For Whiteline)
Sideros
Signwriter
Postby Leon » Wed Apr 23, 2008 9:18 pm
Revhead also does whiteline... I've got two off him recently.
Postby Bling » Wed Apr 23, 2008 9:31 pm
probably best to not bug revhead about parts now :)
Postby Leon » Wed Apr 23, 2008 9:54 pm
it's always a good time to bug revhead
Postby MasCam » Thu Apr 24, 2008 8:24 am
What do you want the rear swaybar for??
MORE oversteer
The title should have read "Hotchkiss sway bars in NZ and cheap place for rear tyres" :lol:
MasCam
Postby barryogen » Thu Apr 24, 2008 11:16 am
The reason for the hotchkiss one is that it has quite a few adjustments/mounts on it so you can go right from stock to ~200% stiffer than stock with the same bar, it means that I can buy one bar, and change it to whatever setting I feel more comfortable with.
After a week of driving I've managed to sort out the oversteer issues... a change in driving style fixed it...
barryogen
Postby Mr Revhead » Thu Apr 24, 2008 11:44 am
hotchkiss? not sure if they will have a supplier in nz
havnt checked the listings for whiteline, but if they do a bar it will be adjustable.
will still be able to supply whiteline :wink:
