Turbo supra motor into non turbo '93 Supra Body.
Postby tsoob » Wed May 07, 2008 2:24 pm
Hey guys, never dealt with the 2J's much. I've got a customer who wants to know if he buys a turbo'd 2J and ECU, and drops it in his non turbo'd body will he need to change his wiring loom and/or trans?Or anythings else for that matter.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby postfach » Wed May 07, 2008 6:10 pm
I would imagine the engine loom is different, can run the trans thats in there now (i assume its an auto? you didn't specify, either way makes no real difference, just be aware that the turbo trans is beefier). I doubt the exhaust will fit either, all other things should be the same, since the blocks are pretty much identical.
postfach
Postby postfach » Wed May 07, 2008 6:11 pm
oh, and probably less of a headache if you source a non-vvti engine for the swap, i would imagine there are quite a few differences between them and the older model 2jz
postfach
Postby the fallen303 » Wed May 07, 2008 7:48 pm
if you had the loom with the engine, then it should just drop in shouldn't it? other than the exhaust and i/c plumbing of course.
true house of JZ
Stay true to the origin
the fallen303
Postby BlakeNZ » Thu May 08, 2008 2:11 pm
manual trans or auto please?
BlakeNZ
Postby tsoob » Thu May 08, 2008 5:04 pm
it has an auto one non turbo trans
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby nite b » Fri May 09, 2008 12:06 am
Done couple of these, require wireups but can do if you need. Also dash will need mod to run tacho. Cost last couple guys about $700 all up.
Convert Ltd
The conversion specialist
nite b
Postby BlakeNZ » Fri May 09, 2008 2:37 pm
use the turbo trans. it is very strong. the non turbo trans will start to die unless you leave the 2jzgte pretty standard.i have a spare if required.
BlakeNZ
Postby mr_monkey » Sat May 10, 2008 2:40 pm
Extra diff bush.
Previous rides: 1992 Toyota Trueno, 1992 Nissan GTI-R, 1985 Toyota AW11, 1990 Toyota SW20 Turbo, 1994 Toyota Supra Twin turbo, 1991 Toyota Soarer Turbo, 1991 nissan Safari
Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
mr_monkey
Postby tsoob » Sun May 11, 2008 7:13 pm
BlakeNZ wrote:use the turbo trans. it is very strong. the non turbo trans will start to die unless you leave the 2jzgte pretty standard.i have a spare if required.
that is his plan, he just wants it to go a bit better.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
