How do you get around not using a electric speedo drive on a blacktop 20v gearbox without it affecting the ECU programming
1- graft in a AE111 speedo?
2- Link ECU?
Zak wrote:You get the speed signal from the back of the cluster.
slighty_sykotic wrote:Zak wrote:You get the speed signal from the back of the cluster.
He wants a mech speedo but the sounds of it, but on a blacktop ecu you NEED to have speed sensor info going to the ecu
Distrb wrote:slighty_sykotic wrote:Zak wrote:You get the speed signal from the back of the cluster.
I never did when i had my blacktop running off the factory ecu in my ae82 fx
I just put a mechanical speedo drive into the gearbox, and it using the speedo cable and factory ae82 dash
slighty_sykotic wrote:It affects the blacktop ecu. ALOT.
Unless you mean that you get the speed signal for the blacktop ecu from the dash!.
Thats the answer, I forgot...
Mech speedo sender in gearbox, speed signal from back for mech dash to the blacktop ecu
