hot off the dyno..
Postby tsoob » Thu Jun 12, 2008 10:50 am
Lith wrote:
escortman wrote:i assume u guys mean t04es? t3/4 are the flanges :wink: but yeh thats will be the limiting factor, dude at work has same engien etc with link and a master power t70 i think just over 300kw atw on 11psi
T3/T4 actually refers to the fact its a hybrid of wheels - not flanges. Most Garrett naming bases on which turbine wheel then compressor wheel family is being used, so with a T3/T4 (which is overly vague) you have a T3 turbine wheel of some sort and a T4 compressor wheel of some sort whacked together in some set of housings. Could be a 50a/r compressor cover and .63a/r turbine housing, could be anything which can be made to fit.
Maxing out below 260rwkw must be a pretty small T3/T4, though one of my mates had a Steve Murch built T3/T4 (not a random nasty) max out by 250rwkw at 18psi on his RB30. Pulled that off and put on a GT3582R and with a bit of tune fiddling it put out over 300kw on the same boost, albeit a little more lag.
The size isin't the main problem, the inlet temp heat is a real problem we are looking at next will be building cold air box etc at the air filter the air temp is 90 degrees.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Titties » Thu Jun 12, 2008 11:17 am
90 degrees at the inlet manifold after the intercooler?
i would suggest cleaning the intercooler, cause if it's that hot after it, it's not doing anything... at all.
even if there is no airflow to the intercooler, it will still take temp out of the intake charge, until it reaches saturation.
How hot are the endtank getting?
For my old turbo car, the in side was hot, the other side was always ice cold.
Cheers, Mike
'98 RS200 Altezza - SOLD
'96 Mitsi Mirage, 11.12 @ 124mph (200kph)
Titties
Postby cat007 » Thu Jun 12, 2008 12:00 pm
no no - as he said - at the air filter the temps were 90
Postby Lith » Thu Jun 12, 2008 2:37 pm
Yeah thats just ridiculously hot at the air filter - how on earth did you manage that? 8O Under bonnet temps shouldn't be anywhere near that high, surely...
2007 Mazdaspeed Axela
Lith
Postby tsoob » Thu Jun 12, 2008 5:34 pm
Note from Matt @ Magwarehouse.com;
It's not a T3/T4, It's garrett GT3582R
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Lith wrote:Yeah thats just ridiculously hot at the air filter - how on earth did you manage that? 8O Under bonnet temps shouldn't be anywhere near that high, surely...
did you see the pics of the manifold?
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Thu Jun 12, 2008 5:41 pm
hahaha yeah I reckon! that's some pretty serious heat!!!
I cant wait to get mine re-done and take some photo's of the manifold haha.
Postby Lith » Thu Jun 12, 2008 7:07 pm
Yah, looks strangely familiar ;)
http://www.youtube.com/watch?v=exBLnyU7fcc
Lith
Postby escortman » Thu Jun 12, 2008 8:50 pm
oo k haha opps my bad
4x4 toyota blizzard offroader
escortman
Postby mjrstar » Thu Jun 12, 2008 8:57 pm
quite a tidy job, i still think my car may be a little looser.
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby soopachargen » Sat Jun 14, 2008 3:13 pm
postfach wrote:I saw this car in the flesh today, damn, its hot. The stretch on the rears is something to behold.
what size tyres is it running on the back?
When in doubt, down and out.
soopachargen
Postby tsoob » Mon Jun 16, 2008 10:53 am
mjrstar wrote:quite a tidy job, i still think my car may be a little looser.
you just need to get out and drift it now!~ :lol:
they are a 205/40/17 on a 9" wide rim the streach is sick
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby cat007 » Mon Jun 16, 2008 11:08 am
I don't understand stretching.
Surely there's a chance the tyre will "pop" off?
Postby barryogen » Mon Jun 16, 2008 11:17 am
indeed there is, it leaves you with pretty much no sidewall flex, so it tends to break traction more easily, so I guess that would help it not pop off.
barryogen
2ZZ Guru in training
Postby tsoob » Mon Jun 16, 2008 11:40 am
barryogen wrote:indeed there is, it leaves you with pretty much no sidewall flex, so it tends to break traction more easily, so I guess that would help it not pop off.
that makes no sense, we have not had one pop off yet and we stretch on a lot of tyres for these drift guys.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby soopachargen » Mon Jun 16, 2008 12:06 pm
haha i have 205/40/17s on my 17x9 .coms too:P what brand did you use? my khumos fitted right up without any trouble, its a pretty crazy stretch tho i do agree.
soopachargen
Postby barryogen » Mon Jun 16, 2008 12:42 pm
tsoob wrote:that makes no sense, we have not had one pop off yet and we stretch on a lot of tyres for these drift guys.
what bit of it makes no sense?
barryogen
Postby soopachargen » Mon Jun 16, 2008 2:08 pm
a low profile tyre is hard to break the bead on when its got no air in it, when they have 36-45 psi surely it would be even harder to get off?
soopachargen
Postby bluemaumau » Mon Jun 16, 2008 7:57 pm
what! do you have 9 inch rims on your wagon soopachargen? :o
Postby soopachargen » Mon Jun 16, 2008 8:08 pm
yeah...17x9s at a 15p offset, check out the wheel thread http://forums.toyspeed.org.nz/viewtopic.php?t=65106&start=120
soopachargen
