Too much volts ????
Too much volts ????
Postby jondee86 » Sun Jun 15, 2008 2:19 pm
I had the battery out of the car for a few weeks, so charged it up
before dropping back in. Now, I have an odd situation with the battery
"check" light on the dash. At idle it is off, but give it a few revs, and the
light comes on !!!
If I add a bit of electrical load by turning on the lights, the check light
goes away, but turns back on when the revs climb. This is pretty much
exactly the opposite of what normally happens when the battery is low.
Battery terminal voltage is 13V at idle, rising to around 15V when revved.
Is this too much volts :? Does the battery check light come on for high
volts as well as for low volts ?? Car runs fine and nothing else has been
touched since it last was running about a month ago.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby Bling » Sun Jun 15, 2008 2:25 pm
13v sounds about right for idle, never checked mine under revs, but it should get to at least 14v under load so 15 is probably fine.
can't help solve the problem tho :oops:
Postby rollaholic » Sun Jun 15, 2008 2:56 pm
hows the alternator?
Postby Leon » Sun Jun 15, 2008 3:03 pm
I've had an AE82 and an AW11 have an alternator failure that meant it overcharged as soon as you got above idle. Though, all the idiot lights came on, not just the alt light.
Postby QikStarlie » Sun Jun 15, 2008 3:47 pm
probably getting a little high. i had one that would creap up to 18v! at that point the ecu would shutdown.
QikStarlie
Re: Too much volts ????
Postby matt dunn » Sun Jun 15, 2008 5:06 pm
jondee86 wrote: Does the battery check light come on for high
Cheers... jondee86
Yes some of them will come on if there is too much voltage,
or is there is too much difference in voltage between the output stud,
and the voltage sensing wire in the 3 pin plug.
Postby jondee86 » Sun Jun 15, 2008 6:11 pm
matt dunn wrote:Yes some of them will come on if there is too much voltage,
I've checked fuses, battery connections and the alternator plug, but
the light still comes on. Seems to be like the voltage sensing circuit is
switching due to a slight over-voltage... maybe an extra 0.5 volts. I can
vary the intensity by changing the revs... like it was on a rheostat.
Matt, do you see any problem in leaving it as it is for a while ??
Is an increase in voltage a sign that the regulator section is in need
of an overhaul ?? This car is not a daily driver, so it is not a biggie to
pull the alternator for testing.
Cheers... jondee86
jondee86
Postby matt dunn » Sun Jun 15, 2008 7:06 pm
put a jumper wire from the main Batt stud to the heavy white sensing wire in the 3 pin plug and see if it fixes it.
If it does not, then the alt is faulty.
Could be the reg, or possibly even one of the diodes,
although diode failures in those alternators are not very common.
Postby Crimson Tears » Sun Jun 15, 2008 10:00 pm
15 volts is definitely too high. Sounds like the regulator has packed up
Crimson Tears
Postby jondee86 » Tue Jun 17, 2008 2:06 pm
Toyota 101 for charging systems states a battery voltage of
14.5V +/- 0.6V @ 2000 rpm with all other electrical loads off.
When the regulator temp is above 80 degF (about 30 degC)
the range is 13.0 - 15.5V.
So 15V measured on a hot engine is not excessive. My concern
is that something in the regulator might be on the way out. If so,
I and would like to catch it before it fails, and perhaps causes
collateral damage to other components.
Cheers... jondee86
jondee86
Postby strx7 » Tue Jun 17, 2008 2:29 pm
most vehicle run between 13.8 and 14.8 volts. if running a vehicle with electric fuel pump, the fuel pump loves getting over 14V compared to the 12.something it would get from the battery.
Postby MAGN1T » Tue Jun 17, 2008 5:53 pm
14.2 is the max you should see on ANY car. If you have a valentine one it will blow up at 15 volts, so will other electronics.
Probably, as above, needs a new regulator.
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby RickGT » Tue Jun 17, 2008 6:46 pm
14.4v is the general charging voltage without load
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Postby MR2SIK » Tue Jun 17, 2008 8:05 pm
so 15v is too high or not??? cos thats what mine sits bang on all the time...
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby jondee86 » Tue Jun 17, 2008 8:39 pm
The Toyota 4A-GE Repair Manual states :
With the engine running from idle to 2000 rpm
Standard voltage:
13.9 - 15.1V at 25 degC
13.5 - 14.3 at 115 degC
So I would say that 15V is at the top end of the acceptable
range, and unless there is some other associated problem,
I would leave it alone.
In my case, the battery check light is flickering on and off,
and I would like to find a cure for that :-|
Cheers... jondee86
jondee86
Postby matt dunn » Tue Jun 17, 2008 10:35 pm
Cheers... jondee86
Yes, you could live with the 15v if you want,
but the light on is a symptom that something is wrong.
Have you tried jumping from B+ to sensing ?
Postby jondee86 » Tue Jun 17, 2008 11:39 pm
Matt, I won't have a chance to check that out until the
weekend, and then I'll post up the results.
Cheers... jondee86
jondee86
Postby MAGN1T » Wed Jun 18, 2008 11:16 am
matt dunn wrote:Yes, you could live with the 15v if you want,
15 volts will fry you battery , will need constant topping up with distilled water.
The max voltage has nothing to do with the car or the model, it's to do with the battery.
MAGN1T
Postby slighty_sykotic » Thu Jun 19, 2008 6:10 pm
I had a mr2 that would give 15v all day every day. (measured with fluke multimeter) And my battery nor valentine 1 ever exploded.
Valentine ones are built pretty well.
And my battery was pretty old and was going fine, no loss of fluid, no boiling etc
slighty_sykotic
Postby MR2SIK » Thu Jun 19, 2008 8:38 pm
When I snapped my alternator belt, I noticed the decline in performance nearly instantly, at 12v it was spluttering and running like a bag of shite.
MR2SIK
