pjay wrote:Just one channel to each voice coil man (4 ohm load). Make sure your gains are balanced though
or
run both subs wired together to produce a 4 ohm load (parallel Voice coils, and series subs) off two bridged channels, and your front speakers (assuming you have some decent ones) off the remaining two channels..
or
buy a mono
i hope i thought of that right..?
dnalunchie wrote:Sometimes I really love this place..... the other 6 days of the week I think $&#$%....those bitches better not bring up my sister.
scotty_ish wrote:Each channel is good down to 2ohm, when you bridge two channels into 2ohm you are effectively forcing each channel down to 1ohm, which is where you may encounter problems.
in saying this you may get away with it, just be aware that it's not recommended. Ive done it before and it's been fine, I'd just hate to say it will be alright and then have it blow up on you.
scotty_ish wrote:So you are using coaxial speakers (mid and tweet together) in your doors for midbass?
Youd be better off getting a dedicated midbass driver. And dynamat extreme in the doors.
Plenty of good advice for this over on nzicemag.co.nz
DeeCee wrote:I have cheaper if you require - its called bostik sound deadening panels - its what the panel beaters put into cars
Capin-Neemo wrote:looking good mang put up a pic when its finished would be interested to see how it goes!
