0.62c /km
Postby sleeektoy » Sun Jul 06, 2008 1:15 am
A side note here which convinced my employer to get company cars.
Insurance usually is valid for private use only, the second you step into the car for work purposes you usually aren't covered. hence the title on most policy's = "Private motor vehicle insurance"
The bad thing for the employer (bonus for you) is that it becomes your place of work and in instances of accidents they may be accountable for losses there.
It is a bit of a gray area in insurance but worth noting if you do use your car for work purposes. Also a good argument to get a company car.
Old school Celica Nuttr x 3 (collection increased)
昭和49年 トヨタ セリカ LB GT (TA27) :D
昭和47年 トヨタ セリカ TRD(TA22)
昭和52年 トヨタ セリカ LB GTV (RA28)
sleeektoy
Postby BlakJak » Sun Jul 06, 2008 9:23 am
sleeektoy makes a fair point.
When i've used my own car for work purposes its usually categorised as 'getting to work where 'work' is not my usual office' - however because i'm still commuting I figure I have a defence should my insurance firm ever give me grief over a claim.
Still if you do regularly use your car for work purposes you best check the fine print on your policy (I use mine infrequently enough that it doesntm ake much difference to me.)
BlakJak
Postby snwtoy » Sun Jul 06, 2008 12:35 pm
Thanks for the heads up, have already looked into getting it registered for business use and personal use. It's actually a couple of dollars cheaper through state for some reason.
AMI are useless/expensive for business.
Will be contacting some brokers this week about it.
snwtoy
Postby MikeMan » Mon Jul 07, 2008 11:01 am
sleeektoy wrote:A side note here which convinced my employer to get company cars.
Insure on a commerical policy and it normally goes down with most companies.
You are now rated with taxi drivers and couriers as "Profrssional Drivers" and therefore less likley to have an accident for some reason? :roll:
MikeMan
Postby AE86less » Mon Jul 07, 2008 5:36 pm
pyro_sniper2002 wrote:
rallymazda wrote:when you ring your kms in at the end of the week or whenever just add on 20- 50 more, ups your rate you see, handy if your job involoves different kms each week
Ways to loose your job 101?
Agreed.
At my old job I got paid 62c p/km when I got sent to training courses, I'd round the figure up, but never more than like 7-8kms. It's too easy to check distances; just put your start and finish points into wises.co.nz and it'll tell you exactly how far it is.
it was pretty good at Hell's Pizza. $2 per drive doesn't sound like alot, but if you pick and choose your drives and get them all going in the same direction it's all good. I was managing about 20 drives per night plus 4 hours wages.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby EVLGTZ » Fri Jul 18, 2008 12:09 am
We use to be 62c / km until sometime last year and been 80c /km since.
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Marz » Fri Jul 18, 2008 1:25 am
Wow, after reading what some of you guys are getting per km, I'm kinda gutted with my rate!
I just landed a job here in Welly as a regional Microsoft rep/merchandiser, while I get a good hourly rate, I'll only be getting 45c per km :cry:
It's not so bad in the wee GT Apex, but 62c per km would be nice :P
Marz
Users browsing this forum: Majestic-12 [Bot] and 1 guest
