cogent wrote:looks about as legit as a warrant sticker on warwicks ke70.
Alex B wrote:To be fair you're never going to fit into OS unless you hate on TS.
Stage 3 Air Magnetism Process:
Subsequent to Stage 2 the air accumulated is pressurized to go through a cavity charged with Neodymium Magnet. In this final stage, the atoms in the air will break into 2 components; ION NEGATIVE and ION POSITIVE. This results in the mixture of Fuel and Molecule with separated IONs. This combustion mechanism achieves a far more SUPERIOR result.
Trls250s wrote:SUPERIOR!!!!! haha whats wrong with a turbo?
AE82 FXGT wrote:Trls250s wrote:SUPERIOR!!!!! haha whats wrong with a turbo?
Are you kidding me? a turbo wouldn't split air 27 ways...
sergei wrote:It is just a spring loaded bypass valve.
It was designed for big hungry carburated V8s to lean out mixture slightly.
Never worked, never will.
Just makes an air leak.
MAGN1T wrote:sergei wrote:It is just a spring loaded bypass valve.
But if your big hungry V8 is cruising at 14 to 1 AFR and the device leans it out to 16 to 1 , then it WILL save fuel.
No point in being 100% negative.
No doubt there are compromises because every modification is a compromise.
Steev
sergei wrote:MAGN1T wrote:sergei wrote:It is just a spring loaded bypass valve.
Steev
Do you sell these?
sergei wrote:http://www.fuelsaving.info/air_bleed.htm
MAGN1T wrote:sergei wrote:MAGN1T wrote:sergei wrote:It is just a spring loaded bypass valve.
Steev
Do you sell these?
No, if I did I wouldn't make any money.sergei wrote:http://www.fuelsaving.info/air_bleed.htm
Like most things on the net, it's not entirely correct.
Steve
The “Micro Compressor” is a performance part that can give your vehicle Increased Horse Power, Better Mileage, and Longer Engine Life without any negative effects to your vehicle engine.
Stage 1 The “Micro Compressor” will substantially absorb surrounded air drawn in, through the air filter. ( Refer to Figure A ).
Stage 2 Compression Mechanism:
The driven air will be split in 27 ways. It is then forced through the Air Separator and through the bottleneck point.
sergei wrote:It was designed for big hungry carburated V8s to lean out mixture slightly.
MAGN1T wrote:Like most things on the net, it's not entirely correct.
Users browsing this forum: No registered users and 26 guests
