Micro Compressor - Dynamic power booster ???
Postby fivebob » Wed Jul 23, 2008 5:29 pm
cogent wrote:
fivebob wrote:
MAGN1T wrote:Like most things on the net, it's not entirely correct.
Care to point out where it is wrong and why???
More importantly could you point out what claims about this device are true, and why they are true???
hey, guy, stop being negative.
8)
OK. I positive that this device is a scam :twisted:
Postby MAGN1T » Thu Jul 24, 2008 10:13 am
We've already been there. The Russsian said it causes an air leak.
Air leaks make the AFR leaner and therefore potentially more economical.
The original idea is fairly sound, unfortunately simple devices don't make money and are easily copied, so the sales & marketing dept. got hold of it and hired the type of people who write articles for car magazines and completely filled the whole thing up with BS, just like in car magazines. Magnets have no effect on fuel and fuel doesn't ionise until the spark plug fires.
In the link provided, whoever wrote it has no idea how a carburettor works, only the idle circuit is adjustable and that only alters the AFR at idle, it has no effect on the main fuel AFR. To adjust that, depending on the type of carb, jets need to be changed.
At WOT, of course it won't have an effect. You don't want it to change AFR then because you need it richer for full load.
Cruising speed is when the majority of fuel gets used.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Users browsing this forum: Bing [Bot] and 17 guests
