Cogent wrote: there is a fraudulent cogent-post in your sig and i insist that you cease displaying it immediately or else i'll track you down and perform acts of homosexuality on your face
Looonie wrote: the soarer is the sexy, sultry, curvy sister that looks infinitely better and is sophisticated and smooth but still has a bit of a bite
http://soarercentral.com/sc-forum/messages/67/445.htmlmr_monkey wrote:Possible to make the cruise control work past 108kph? wtf is that sh*t.
Good luckmr_monkey wrote:Anyone seen stock weights for the cars and what can be removed? eg weight of sound proofing etc.
Most suspension parts, with a few catches. And seats. Ignoring of course JZ related bits.mr_monkey wrote:what supra parts are interchangeable with the z30?
mr_monkey wrote:Are dodgey fuel senders/gauge common? mine seems to have a mind of its own.
mr_monkey wrote:My boot was wet inside this afternoon. Is there a common leakage spot there for water?
mr_monkey wrote:What chassis code should I have if there is an LSD in my car? i cant decide if its open or factory LSD.
mr_monkey wrote:Some soarers came with a sub? was this in the middle of the rear parcel tray? (is there a spot there where i can install one- using boot as the enclosure)
mr_monkey wrote:AND.. I have no internal lighting from the middle centre celling assembly. Just opened it up and it had one random bulb sitting there which didnt have a hope of working... and i have absolutely no idea how the three compartments actually hold any sort of bulb. I cannot even see positive and negative terminals! just htat spring steel loop which is rivited to that sheetmetal base thing. so strange. Anyone know how this sh*t works?
Trls250s wrote:Soarers are good. People moan they are whales but damn can they lay down some skids.
mr_monkey wrote:Trls250s wrote:hope to get it below 1500kg
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 12 guests
