Clutches
Clutches
Postby samlloyd » Sun Jul 27, 2008 9:45 pm
The other day i managed to destroy an exedy 5puck, so im in the mids of replacing it.
Ive got the old clutch and box out. Just working on getting these flywheel bolts out with limited time/skill :lol:
Rb30det, with a 30box. Push type? Im not sure, i dont know anything about this sorta stuff.
Im looking at twin plates, dont want to spend over 1500.
Anyone recommend where to go, and good clutches/dealers
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby hsmidy » Sun Jul 27, 2008 10:09 pm
i got a twinplate clutch kit with a push pull conversion kit and flywheel for 1500, was secondhand but mint as you shouldnt have to much trubble, that was from re sinclair
hsmidy
Postby Akane » Mon Jul 28, 2008 1:39 am
Unless you got power tools, don't bother trying to undo the flywheel bolts. Last time I tried, I slipped and busted my finger open :lol:
Postby escortman » Mon Jul 28, 2008 7:48 am
how much power are u putting out ?
4x4 toyota blizzard offroader
escortman
Postby samlloyd » Mon Jul 28, 2008 8:15 am
currently 240, will probably see 300 one day. With a lot of torque to boot
samlloyd
Postby cogent » Mon Jul 28, 2008 9:34 am
Akane wrote:Unless you got power tools, don't bother trying to undo the flywheel bolts. Last time I tried, I slipped and busted my finger open :lol:
so you might say that you had...no...grip??
XD XD
cogent
Postby sergei » Mon Jul 28, 2008 10:55 am
You don't need power tools to undo bolts, what you need is a good 6 point socket and a power bar, also I made a plate that locks the flywheel in place (using the starter ring teeth).
Postby Akane » Mon Jul 28, 2008 3:38 pm
XD XD
ba-dom-pishhhhhhhhhhhhhhh :evil:
Sergei: Mine was stuck on so nicely, I asked a mechanic friend to help me, he bought a compressor and a rattle gun, the rattle gun just sat there rattling for about 30sec+, with the trigger on/off/on/off, then a few of those bolts finally came loose.
Postby Bazda » Mon Jul 28, 2008 4:36 pm
You shouldnt need a twin plate.
You can get a rb30 clutch with massive LBS. The exedy ones arent that high in the lbs area. People buy them cos its exedy lol.
Get a standard pressure plate, take it to Auto Clutch (ring and arrange it then send to them). They will beable to get the standard one up to maximum clamp force for the power you want and they will also suggest a clutch plate to use.
Postby 99gtt » Mon Jul 28, 2008 5:08 pm
Bazda wrote:You shouldnt need a twin plate.
2nd that auto clutch is the only place to go for performance clutches.
SOON TO BE 500 HP
99gtt
Postby touge rolla » Mon Jul 28, 2008 5:30 pm
smithers wrote:currently 240, will probably see 300 one day. With a lot of torque to boot
kW? Surprised the gearbox is holding up if so, is it just a standard rb30e box?
touge rolla
Postby samlloyd » Mon Jul 28, 2008 6:27 pm
Yes to all the above. Im getting new bearings and replacing syncros in it aswell. My gearbox man reckons it will be ample. Same gearset as terrano's.
And i did email autoclutch. Seem like real good fullas, told me heaps more then i asked with a few options.
Performance Cover Part No Ref N-015 X uprated to approx 4000lbs Clamp
Performance Disc Part No Ref AC240CK with Dampened Hub and steelbacked Carbon Kevlar Friction Material
OR
f you intend to go drifting we would suggest a 5 Puck Full Ceramic Disc with either Dampened Hub or Rigid
(removed pricing from quote but very competitive!)
is 4000lbs pretty decent?
samlloyd
Postby Dell'Orto » Mon Jul 28, 2008 7:07 pm
4000lbs = 1.8 ton 8O Its pretty massive clamp pressure.
Postby Lloyd » Mon Jul 28, 2008 10:38 pm
Akane wrote:Sergei: Mine was stuck on so nicely, I asked a mechanic friend to help me, he bought a compressor and a rattle gun, the rattle gun just sat there rattling for about 30sec+, with the trigger on/off/on/off, then a few of those bolts finally came loose.
Quite often a bar can get stuff off that a rattle gun cant. You just gotta lock the flywheel up, which is what lever bars, rings gears and one bellhousing bolt are for
Postby mjrstar » Tue Jul 29, 2008 2:32 pm
Dell'Orto wrote:4000lbs = 1.8 ton 8O Its pretty massive clamp pressure.
yeah i suggest you don't start the motor with your foot on the clutch, or it'll be bye bye thrust bearings.. i run 3200 lb single plate on my car with 240kw and it's holding up well..
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby samlloyd » Wed Aug 27, 2008 9:48 pm
Got my new autoclutch in. Feels very nice. Still driving like a pussy on it, let it bed in etc.
And to those who have read some of my previous threads,
I GOT A CERT 8)
samlloyd
Postby matt dunn » Wed Aug 27, 2008 10:35 pm
sergei wrote:You don't need power tools to undo bolts, what you need is a good 6 point socket and a power bar, also I made a plate that locks the flywheel in place (using the starter ring teeth).
A trick I have used one or twice is a short piece of chain,
bellhousing bolt through one link, and bolt another to the nearest pressure plate bolt hole,
But make sure you use a decent lenght bolt through the flywheel to not damage the threads.
Users browsing this forum: No registered users and 40 guests
