Increasing boost with internal gate
Postby l1ttle_d3vil » Wed Jul 30, 2008 10:52 pm
If I'm wanting to increase the boost of a standard T28 by using electronic boost control and sticking with the internal wastegate, what is a "safe" limit I could increase it to while allowing it to vent easily?
I've heard of people running 15psi on the internal gate with very minimal spiking (and thats using the VERY old link ecu's, which apparently are no good for boost control).
Would this be on the limit, or could I go higher?
would it be worth it to bore the gate out a bit to allow more airflow or would the gains from that be minimal??
thanks
Postby tsoob » Thu Jul 31, 2008 4:19 pm
get an external bro, they cheap as now and way better at the mid range boost 14-20 psi
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby samlloyd » Thu Jul 31, 2008 8:28 pm
Not the same turbo, but i had 18 odd psi kept undercontrol by an internal on my old Mazda Familia.
Now on my RB, its got a t3/t4 on it, and the internal wastegate couldnt keep up. Got the wastegate hole bored out just a bit less then the flap (about 9mm!) and it holds boost ok now.
Although in near future, the wastegate/turbo is whats limiting power. Depends how much your after if you want to go external or not.
And price too, genuine orrr?
Karl Pilkington On seals - "Its between a fish and a dog."
samlloyd
Postby DexGT » Thu Jul 31, 2008 10:07 pm
I'm running a GT25 and it is standard and I am running 20PSI controled though the internal wastegate so 15psi should be fine , only one real way to find out though :wink:
DexGT
Postby escortman » Thu Jul 31, 2008 10:43 pm
cheap externals are fine so long u take out the shit springs and put a good quality one in, im going to see how far i can keep internal gate for
4x4 toyota blizzard offroader
escortman
Postby mister2 » Fri Aug 01, 2008 12:05 am
Internal gates are perfectly fine for what you want to do.
You don't need a big wastegate. Porting wastegates and going to externals is only if the internal can't hold boost *below* a certain level. Whereas yours is presumably fine at spring pressure?
If your stock turbo creeps at spring pressure (see Redmist's offroader) then that is when you need to start looking at externals or porting wastegates.
www.nzefi.com
4WD Dynapack Dynamometer.
Link, MoTeC, Greddy, Power FC sales support and tuning.
Weapon of Choice: 1992 NSR250 SE
On hiatus, current location: Cambridge, UK
mister2
Postby touge rolla » Fri Aug 01, 2008 1:06 am
an HKS actuator is a relatively popular upgrade on T28's
http://www.hksusa.com/products/?id=665
touge rolla
