IH8TEC wrote:i went in it around taupo, yeah was scary and has a poo load of torque for a little light car. tends to flick the ar*e out quite happily.
rollaholic wrote:its only running 9 psi, whats the stock boost for 2jz?
also, 206kw is the factory quoted power, presumably at the flywheel, (whereas the 169kw is atw i guess?) and we all know what toyota is like with its numbers *cough*20v*cough*
whatever the case, 169kw is plenty for a car that size, but to my mind if you are going to put a 2JZ in a car like that it needs to be making 300kw plus - otherwise why not stick with turbo 4age?
Users browsing this forum: No registered users and 26 guests
