Blacktop Rebuild - ChCh
Postby Flunk » Sun Aug 10, 2008 2:19 am
So what sort of money should i be looking at to have my blacktop rebuilt?
and whos a reliable outfit to get to do it, in chch?
well, when i say rebuilt, i presume this is what it need,s i know blacktops use a little bit of oil, but mine is using allot lately, and puffing smoke when you give it assholes.. so im guessing its time for some new rings etc...
Flunk
Postby touge rolla » Sun Aug 10, 2008 3:30 am
Cliff Bond on Ferry Rd
touge rolla
Postby Bling » Sun Aug 10, 2008 10:35 am
how much is a lot of oil?
also, how much time does it spend high up in the revs?
mines been using "a lot" since I bought it nearly 5 years ago :lol:
Postby Flunk » Sun Aug 10, 2008 3:51 pm
i usually have to put about a litre a week in it, sometimes 1 litre per fortnight.... its spent most of its life, in the higher end of the rev range :)
Flunk
Postby Crampy » Sun Aug 10, 2008 4:52 pm
Flunk wrote:i usually have to put about a litre a week in it, sometimes 1 litre per fortnight.... its spent most of its life, in the higher end of the rev range :)
That is quite a bit.
Are you using a catch can at all?
Crampy
Postby Flunk » Sun Aug 10, 2008 5:29 pm
neg. the only modification was the removal of the factory airbox, for a stailess option + pod.
Whats involved in installling/running a catch tank? will this help?
Flunk
Postby Bling » Sun Aug 10, 2008 5:45 pm
hmm yeah the higher the revs the more oil you will use, so you can either just keep topping it up and it will probably keep running.
Even with a rebuild it might not be long before its burning oil again.
However, send B1NZ a PM as he had his rebuilt under similar circumstances I think
