sergei wrote:It will be a lot cheaper than gas, even if the electricity is "so expensive".
Jdawg wrote:What car were you planning on using?
You may get better performance using a kit car or hot rod type rather than an old shitter like a tredia. You would be able to keep the weight down and looks far better.
molex wrote:You're not taking into account additional losses through the transmission/driveline etc, much of which can be avoided with electric.
neo wrote:I'm still trying to get an explanation why you wouldnt want gears.. I know there is linear power delivery, but acceleration must suffer with a single fixed ratio.
