Got a water leak coming from the back of the engine. too dark to see where its coming from now, but is there a hose or pipe that i should be looking for?(or pipe that commonly fails?)
speedo stopped working as well, likely to be just the speedo cable? or something else i need to check.
ecu gives me code 42
VEHICLE SPEED SENSOR SIGNAL CIRCUIT--NO SPD. SIGNAL FOR SEVERLA SECONDS
WHILE VEHICLE IS OPERATED UNDER HEAVY LOAD (TPS/MAP/AIR FLOW INPUTS)
--SPEED SENSOR/CIRCUIT
--ECU
