best brand aftermarket twinpot ae101 rotors? prefer slotted
Postby Crampy » Mon Sep 08, 2008 7:03 am
On the same site:
COROLLA/RUNX/ALLEX
ZZE 123 - Sportivo DBA759.
diameter: 275mm
height: 50mm
thickness: 25mm
centre hole:55mm
bolt holes: 4
Already 4 stud, so no need to drill them out to suit.
Crampy
Postby Jet_boy01 » Mon Sep 08, 2008 7:59 am
Oh yeah, they are the exact diameter and width aswell. Wonder what they are worth a pair, probably have to part with $300 I guess? Anyone know what DBA's are roughly worth?
Jet_boy01
Postby Crampy » Mon Sep 08, 2008 8:03 am
I got some priced up through BNT, but sadly can't remember how much they were.
They didn't have them in stock, so would need to get them sent from Australia.
Crampy
Postby slammed_integral » Mon Sep 08, 2008 7:20 pm
Hi. Yes we can do those. $379.95 per Pair incl GST for znoellis off trademe just confirming now if it is 54mm or 55mm center
http://www.cardomain.com/id/slick_ep
there is nothing sour cola worms cant fix...
slammed_integral
Postby Jet_boy01 » Tue Sep 09, 2008 12:21 pm
Is that for the Sportivo's, $369 for a pair of those? Can imagine DBA would be even more expensive then...
If our exchange rate gets better again, something off here could be worth a shot
http://www.greenline.jp/catalogue/bccat ... suspension
Couple of superstrut discs in the mix there, slotted and heated disc spec available.
Jet_boy01
Postby strx7 » Tue Sep 09, 2008 12:38 pm
Crampy wrote:On the same site:
COROLLA/RUNX/ALLEX
diameter: 275mm
height: 50mm
thickness: 25mm
centre hole:55mm
bolt holes: 4
std retail at repco on these discs is $249 each.
I can supply them for $81 each + freight
Postby Jet_boy01 » Tue Sep 09, 2008 12:51 pm
Is that for the DBA ones?
Very keen if so!
Oh could you get the slotted ones, part number DBA 759SL & DBA 759SR
Would love some one to be able to confirm they will def direct fit a superstrut levin however...
http://www.dba.com.au/view_product.php? ... es_id=5730
Jet_boy01
Postby strx7 » Tue Sep 09, 2008 4:50 pm
yes thats a DBA759 std
Postby slammed_integral » Tue Sep 09, 2008 6:50 pm
COROLLA/RUNX/ALLEX
diameter: 275mm
height: 50mm
thickness: 25mm
centre hole:55mm
bolt holes: 4
yeh thats way better than what the guy saiud for on trademe. 1 question though, would these be the same ''offset'' as ae101 gtz rotors?
slammed_integral
Postby AE82 FXGT » Tue Sep 09, 2008 6:53 pm
That's what the height is I believe
AE82 FXGT
Postby neo » Tue Sep 09, 2008 11:05 pm
COROLLA/RUNX/ALLEX
diameter: 275mm
height: 50mm
thickness: 25mm
centre hole:55mm
bolt holes: 4
Crampy for the win, I couldn't navigate the new site... Gimme a PDF / parts catalogue any day
neo
Postby strx7 » Tue Sep 09, 2008 11:06 pm
anyone got a AE101 super strut rotor to measure up?
Postby Grrrrrrr! » Wed Sep 10, 2008 1:47 am
Jet_boy01 wrote:Is that for the DBA ones?
Very keen if so!
The numbers look right, but i no longer have the receipt from when i got some for my superstrut 101 to confirm. They are a perfect fit if they are the correct ones.
Grrrrrrr!
Postby Crampy » Wed Sep 10, 2008 6:59 am
I've asked about these rotors on an earlier thread and someone pointed them out to me.
When I rang BNT with the part number, they were listed on the computer as rotors for an AE111 from memory, not the just the RUNX or ALLEX as stated in the catalogue.
Much easier than machining the entire rotor diameter down and re-drilling from five stud to four stud 8O .
Crampy
Postby 1I1 » Wed Sep 10, 2008 10:48 am
strx7 wrote:anyone got a AE101 super strut rotor to measure up?
I have a pair at home i can measure up tonight.
TRD Clicky >>Here
1I1
Postby strx7 » Wed Sep 10, 2008 1:41 pm
sweet, post the info and you'll make a lot of people either very happy, or sad
Postby slammed_integral » Wed Sep 10, 2008 11:44 pm
hey man, how did you go? im quite eager mc beaver over here ay, thanks
slammed_integral
Postby 1I1 » Thu Sep 11, 2008 9:46 am
Sorry dude didn't get home till late last night - shall venture into the shed tonight definately!
TRD Clicky >>Here
1I1
Postby 1I1 » Fri Sep 12, 2008 9:39 am
This is what i came up with:
Diameter: 275mm
Height: 48mm
Thickness: 26mm
Centre Hole: 55mm
Bolt Holes: 4
TRD Clicky >>Here
1I1
Postby Crampy » Fri Sep 12, 2008 11:36 am
So it seems to be a reasonable match.
Is the difference in height (48mm vs 50mm) going to cause any problems?
Crampy
Users browsing this forum: Bing [Bot] and 33 guests
