RomanV wrote: Mr Mainstream: The king of the Pushrods?!
CozmoNz wrote:Running rich only occur's in Air Flow meter'ed car's
where the PISSHHHH noise releases the boost when the engine's ecu belives it will receive that air. and injects the approperate fueling.
with a map sensor'ed car, the ecu will only inject what the engine *thinks* (due to mapping etc) it will need fuel wise... i think thats right, so @ x of vac, it injects x of fuel.
losing that air / boost, results in higher vac / lower boost whatever, so less fuel is required, since less pressure exists.
thus, wankie bov's on afm'ed cars = silly and cause engine to hate you
wankie bov's on map sens0rz0red cars = the shiz wizza gizza
vvega wrote:
ps dr-x is a crack head
Santa'sBoostinSleigh wrote:so would a vented BOV be a good thing or a bad thing on a caldina?
event2 wrote:dont u get continued acceleration on a supercharged engin if u hav a frount mount inter cooler and lots of pipeing? would a blow off valve stop that in this situation?
Dragger_Dan wrote:It's amazing to listen to the amount of excessive noise people make with BOV's and screamer pipes. The thing I don't get, is why do you sometimes hear a BOV on a full throttle gear change... isn't that counter productive? Shouldn't a well tuned setup mantain boost pressure at WOT changes to keep as much power as possible?
Dr-X wrote:No, they're wanky because on 99% of applications they're pure rice. So morons like you can cruise through town in 1st and go 'listen to maah phat blow off valve, braaaah, it's turbo braaaah'.
