supra single dyno
supra single dyno
Postby avinesh » Sat Sep 27, 2008 2:04 pm
car made 230wkw at 13psi afr was about 10.2:1 which is damn rich just waiting for larger injectors then will turn it up to 18-20psi an try to crack 320wkw.......for the people who dont know car is a auto jza80 supra with master power t70
220.1 rwkw
jzz30 bpu soarer auto = 13.3 @ 171 km/h
jza80 supra = 11.7
jza80 apu supra manual = 400rwkw
avinesh
Postby Adydas » Sun Sep 28, 2008 12:04 am
What about this is a tech question?
Adydas
Postby Py7h0n » Sun Sep 28, 2008 11:04 am
That is really sad for a T70.
My JZA80 made 250wkw on the stock turbos (can't remember boost but I think was around 16psi).
Py7h0n
Postby 2jayzgte » Sun Sep 28, 2008 11:49 am
I think there will be a bit more to come as I think he is only using the factory ecu once he gets something to tune with he'll probably see a fair bit more.
2jayzgte
Postby avinesh » Sun Sep 28, 2008 1:09 pm
Py7h0n wrote:That is really sad for a T70.
yea just found out afr was not even in the tens it was below that thats why there was a flat line when boost kicked in for fuel....damn ohh well im tunning it next when i get 550cc injectors an pump up the boost to about 18psi.....oh an the car gained almost 10rwkw from upping the boost by 0.5psi 8O
220.1 rwkw
jza80 supra = 11.7
avinesh
Postby escortman » Sun Sep 28, 2008 3:08 pm
y dnt u turn the boost up before putting the 550s in?
4x4 toyota blizzard offroader
escortman
Postby avinesh » Sun Sep 28, 2008 3:35 pm
escortman wrote:y dnt u turn the boost up before putting the 550s in?
waste of money coz then ill have to pay for dyno twice... an we did first dyno run just to make sure car is running safe.........
220.1 rwkw
jza80 supra = 11.7
avinesh
