Rebuilding 2tb twin carbs
Postby Josh » Thu Oct 09, 2008 1:07 pm
Was going to go for a side draft setup but because of lack of funds i mite just rebuild the standard twin carbs, does anyone know if i can buy carb rebuild kits anywhere, also a workshop manual, to assist with the rebuild
2tb kp60
Josh
Postby gepsk8 » Thu Oct 09, 2008 7:54 pm
where are u?
O272754663
gepsk8
Postby lucasthefallen » Thu Oct 09, 2008 9:28 pm
get a genuine toyota kit, you shouldnt need a manual, just dont loose any of those tiny balls or springs. i normally lay a clean rag out and do it on that, so things dont roll away. some a/m kits come with plastic plugers etc, dont use them, if you current ones are metal then keep them.
what exactly is wrong with the carbs? why are you rebulding them? quite often they just need to be set up right.
Need Service or Repair work done? send me a PM
lucasthefallen
