postfach wrote:Supras have single piston slide calipers.
Does the caliper have pistons on both sides or just one?
Adoom wrote:I'd rekit them and with new pistons as well. The kits usually dont cost much but that last dust seal that goes on the end of the piston is a biarch to get on. Make sure you get some brake assembly/rubber grease when you buy the kit cause it makes the rubber slide over the piston better and less chance you will tear it trying to get the b**tard on.
cat007 wrote:Adoom wrote:I'd rekit them and with new pistons as well. The kits usually dont cost much but that last dust seal that goes on the end of the piston is a biarch to get on. Make sure you get some brake assembly/rubber grease when you buy the kit cause it makes the rubber slide over the piston better and less chance you will tear it trying to get the b**tard on.
Any idea's roughly what the rebiuld kit's worth? And where you get it from?
cat007 wrote:per corner I assume??....
rollaholic wrote:must say genuine parts seem to get more competitve by the day, specially for toyotas. tis awesome to see!
