Anyone want Sheetmetal Work Or Powdercoating
Postby Mr. Mainstream » Thu Oct 09, 2008 10:52 pm
Quiet At Work So If Anyone Would Like any sort of sheetmetal work done eg Airbox, panels, bench covers, shelves etc etc am able to do cheap Stainless, galv, Marine grade most types of metal up to 3mm-3.5mm with full access to CNC tools.
Can also Powdercoat to a high standard anything unless crazy long. black and white cheap. other colours are at a slight premium. willing to acid wash but up to you to prep/blast.
gimme yell if wanna grab some off-cuts/scrap etc also :)
Slide Me A PM
Last edited by Mr. Mainstream on Fri Apr 29, 2016 8:50 pm, edited 3 times in total.
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby repowered » Fri Oct 10, 2008 7:28 pm
hey I have a bit of checker plate (about 280x170) filling in a gap in my dashboard where the stereo and ash tray went. i currently have it mounted in the glovebox. reckon you could weld some mounts to the back of the peice of checker plate and cut a hole for the head unit.
maybe give you the bit of checkerplate and dimentions of head unit? should really make some mount to attach it to the dash frame to support it properly but mite b ok without it, and you would need to have the car for that. carsa ke30 corolla
Rollin!
repowered
Postby Bling » Sun Oct 12, 2008 11:25 pm
Cut the hole with a grinder and fix it in place with come Velcro strips.
Thats how i'd rangi it up anyway :lol:
Postby repowered » Mon Oct 13, 2008 1:44 pm
haha yea rangai alright, its rangi enough in the glove box as it is!
Rollin!
repowered
Postby repowered » Tue Oct 21, 2008 5:29 pm
cheers for doing that mainstream was tidy mint as job. Just need to do that other bit i PM'd you about hope you can help.
Rollin!
repowered
Postby Mr. Mainstream » Mon Jan 19, 2009 10:50 pm
Hey guys back and work and have a bit of time on hands for off-job. PM or txt any sheetmetal needs
Last edited by Mr. Mainstream on Fri Apr 29, 2016 8:51 pm, edited 1 time in total.
Various Others
Mr. Mainstream
Postby frost » Sat Jan 24, 2009 1:11 am
repowered wrote:hey I have a bit of checker plate (about 280x170) filling in a gap in my dashboard where the stereo and ash tray went.
haha i have the exact same scenario in my 85levin. checker plate is so 2001 :)
Postby Mr. Mainstream » Tue Jan 27, 2009 3:33 pm
it does the job :lol:
Various Others
Mr. Mainstream
Postby 4-AGE 4-LIFE » Wed Jan 28, 2009 11:16 pm
Are you able to make manifold flanges? 10mm steel?
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby crispy'86 » Thu Jan 29, 2009 6:30 am
For that, depending on exactly what engine it's for, you might be able to get something like that through either Autobend or Chase exhaust supplies
crispy'86
Postby Mr. Mainstream » Thu Jan 29, 2009 9:55 am
10mm steel exhaust flange?
Various Others
Mr. Mainstream
Postby hsmidy » Thu Jan 29, 2009 7:01 pm
wouldnt happen to be handy when it comes to drop tanks would ya?
hsmidy
Postby 4-AGE 4-LIFE » Thu Jan 29, 2009 8:20 pm
I need to get 3 flanges made, i have gaskets for all of them for sample sizing.
1 is a turbo > manifold flange vf10 turbo.
the other is, manifold > head flange, 4 cyl 2.0l
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby Mr. Mainstream » Thu Jan 29, 2009 10:52 pm
4-AGE 4-LIFE wrote:I need to get 3 flanges made, i have gaskets for all of them for sample sizing.
yeah should be able to do, what thickness and material?
Various Others
Mr. Mainstream
Postby 4-AGE 4-LIFE » Fri Jan 30, 2009 10:13 am
10mm, just mild steel. if thats what it is called.
ive actually changed my design again.
i only need the turbo > manifold flange made.
when and where can i drop the gasket off to you
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby Mr. Mainstream » Fri Jan 30, 2009 11:18 am
dont deal with metal 10mm thick. we do 1.6mm to 3-5mm., i work 2;30-1030pm in ricc
Last edited by Mr. Mainstream on Fri Apr 29, 2016 8:50 pm, edited 1 time in total.
Various Others
Mr. Mainstream
Postby Bling » Fri Jan 30, 2009 5:04 pm
Au bro just glue 2 5mil bits together :lol:
Postby Mr. Mainstream » Fri Feb 06, 2009 12:25 pm
BZG|Bling wrote:Au bro just glue 2 5mil bits together :lol:
thanks bud :lol:
Various Others
Mr. Mainstream
Postby Dirtbag » Fri Feb 06, 2009 7:26 pm
Are you able to mod an already existing catch can? I am not sure at all of the internal structure, would like to check if a baffle is in there and then add steel wool and possible get a bracket added to it?
AE101 GT-APEX Superstrut
My profile!
Dirtbag
Postby Mr. Mainstream » Sat Feb 07, 2009 6:25 pm
have sent PM :) . sorry if i havnt replied to any PM's as my inbox was full :oops: . please resend.
Various Others
Mr. Mainstream
Return to Christchurch / Upper South Island Region
