BZG|Bling wrote:Sounds pretty cut and dry to me
You are just lucky your mig works I guess on 10A. I'm sure it wouldn't be too expensive to run a wire capable of running 15A.
BZG|Bling wrote:Possible to trench to the garage from the house? Ducting is a good option.
jondee86 wrote:The wire behind is the same
bit of wire, just connected to a higher rated socket.
Dr J wrote:im priddy sure you can get adaptors to so you can plug them into 10 amp plugs. Yes you could burn out you wiring but only if you use it at full noise for prolonged lengths of time.
Users browsing this forum: Google [Bot] and 24 guests
