1981 toyota starlet
1981 toyota starlet
Postby Nezza » Sat Oct 25, 2008 1:17 pm
Hey
I have a 1981 toyota starlet hatch kp60 with 2k engine. Am keen as to upgrade as both engine and gearbox are very tired. Im wanting a bigger engine and new 5-speed box that will prety much fit straight in without to much hassel. Any info will be muh appreciated
Nezza
Postby Lloyd » Sat Oct 25, 2008 1:25 pm
Find a 4K or 5K with box to suit. The KE20 and Starlet boxes should fit in fine, might find the shifters are in a slightly different spot in the KE30 onwards ones.
Engines should bolt straight in no worries at all
Postby Dell'Orto » Sun Oct 26, 2008 9:04 am
A 5K will need the sump swapped, otherwise bolt in easy as. Later Corolla boxes will need you to chop the hole in the trans tunnel slightly longer to fit the shifter.
Postby Nezza » Sun Oct 26, 2008 10:41 am
How easy would a 4A-GE bolt in?
Nezza
Postby Mr Revhead » Sun Oct 26, 2008 10:50 am
in a case like this, i would say that if you have to ask.... hard
its been done many many times
and its certainly not the hardest thing out there
but you will need to modify a few things
and some some decent wiring and fuel system mods
Postby Nezza » Fri Nov 14, 2008 10:34 am
would a k50 gearbox fit into a kp60 1981 starlet?
Nezza
Postby AE86less » Fri Nov 14, 2008 11:10 am
If it's 5 speed then it has one already.
If it's 4 speed, then yes, very easily.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby Dell'Orto » Fri Nov 14, 2008 11:36 am
Yes provided the car is already manual and you're using a Starlet K50, otherwise theres a bit of fiddling required.
Postby Nezza » Fri Nov 14, 2008 3:12 pm
At the moment car is 2k with 4-speed gearbox
Am wanting to put in 4k with 5-speed gearbox (k50)
Nezza
Postby RS13 » Fri Nov 14, 2008 4:40 pm
I've done that exact conversion.
If you've got a 5-speed out of a KP then its' easy as.
Everything bolts up to what you've got, although my 4k dizzy was electronic and not working so I just swapped in the 2k dizzy and it ran mint. Intake and exhaust manifolds bolt up no worries, as do the engine mounts. I had to use my 2k fuel pump in the 4k as the one that it came with was shagged.
The 5speed gearboxes out of the DXs are slightly longer, they bolt up to the engine and mounts fine, but the shifter is further back so you've got to grind a little bit of the trans tunnel away to get it to fit nicely. No biggie.
Having a 4k makes a huge difference.. best $80 I ever spent, lol!
4AGE.. big, difficult and considerably pricey job, parts are getting very hard to come by now. You need to wire up the car to suit injection, new fuel lines, mod engine mounts, so already a much harder job than a 4K. And its' definitely a stick it in the garage for weeks job, whereas you can easily do the 4k swap in an afternoon.
RS13
Postby GTTpower » Fri Nov 14, 2008 7:39 pm
Ive heard its possible to swap tail housings between starlet and corolla k gearboxs, saves cutting a hole in the tunnel.
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Steam/Origin ID: nzEP85
GTTpower
Postby Jdawg » Thu Nov 27, 2008 4:43 pm
I know of a starlet in the same condition, Can you put a turbo motor out of a later EP starlet into old KP
Jdawg
Postby 88gtz » Thu Nov 27, 2008 5:19 pm
Sure can...............if your wallet is deep enough
*cough* viewtopic.php?t=62472 *cough*
88gtz
Postby Jdawg » Thu Nov 27, 2008 6:13 pm
Thanks, didn't know what the engines were called so my searches weren't too successful, mostly coming up with 4A-GE conversions
Jdawg
Postby MRT1TRD » Thu Dec 04, 2008 11:30 pm
Your best bet is to look on
www.club-k.co.nz
as thats all they talk about eg: 20v starlets etc
So you wanna be a Garrage superstar,
Live large, Wit a big garrage, Wit five cars
http://toyspeed.blakjak.net/profiles/profile.php?id=43
MRT1TRD
