Ae86 diff heads
Ae86 diff heads
Postby beeker » Mon Oct 27, 2008 3:22 pm
Are they all the same ? between facelist and pre facelift ?
Obviously there is different ratios and LSD/Not LCD.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby rollaholic » Mon Oct 27, 2008 4:00 pm
no, facelift diff takes slightly larger diameter axles.
the measurements are on the forums somewhere if you do a search, i asked a similar question a while back
for what its worth, when i asked revhead about it facelift axles were still available brand spankers from toyota for a pretty reasonable price.
Postby d1 mule » Mon Oct 27, 2008 4:29 pm
from memory Pre facelift have 24mm axels and facelift have 25mm axels
d1 mule
Postby beeker » Mon Oct 27, 2008 4:56 pm
I recognise that the axles are different. Let me explain further, i need a dif head to fit a brand new LSD which i'll purchase. The LSD is likely to be the facelift version, taking the facelift axles. Its for competition use, this why i want new, and also the stronger units.
So back to the original question, putting aside the LSD unit which i assume the axles slide directly into, is the Diff head the same between pre and post facelift? I seem to remember someone saying there was two different bolt# versions, and one was stronger. But i might be talking rubbish, and getting confused.
06 RS4 Avant
beeker
Postby rollaholic » Mon Oct 27, 2008 6:04 pm
ah i see what you are saying. when you say diff head most people think you are referring to the actual LSD itself, when you are actually meaning the carrier.
to the best of my knowledge, the carriers are all the same.
Postby beeker » Mon Oct 27, 2008 6:55 pm
rollaholic wrote:ah i see what you are saying. when you say diff head most people think you are referring to the actual LSD itself, when you are actually meaning the carrier.
Cool thx.
WTB: 1x AE86 Carrier then!
What do they go for ?
Already got an axle housing and new axles ready to go. Still gotta get a facelift TRD LSD.
06 RS4 Avant
beeker
Postby rollaholic » Tue Oct 28, 2008 7:19 am
not really too sure - cant recall ever seeing one for sale without a diff in it.
that being said, open T series diffs are probably around the $100 - $150 mark. centre probably still worth a bit to someone to turn into a locker once you have your LSD in place too.
Postby AE25 » Fri Oct 31, 2008 11:37 pm
to me the carrier is the part the crown wheel bolts onto with the spider gears or lsd inside. the head is the complete unit that bolts into the diff housing.
there are variations to the diff head casting. some have a longer stud, usually for the taller ratios like 3.9:1. but swap the longer stud with the head and it'll swap across.
E2 & E7 fanatic
'71 ke26 '75 KE25 SR 4AGE '78 bug KP60 '83 KE70 SR Coupe 3TGTE '84 ke74 '84 ae85.6 trueno '84 YN57 SR5 '86 AE82 FXGT 20v '91 ST185 '92 SW20
http://www.toycrazy.net
AE25
Postby beeker » Sat Nov 01, 2008 6:35 am
AE25 wrote:to me the carrier is the part the crown wheel bolts onto with the spider gears or lsd inside. the head is the complete unit that bolts into the diff housing.
Thx, will also look to get a 4.77 for it, probably from palmside.
06 RS4 Avant
beeker
Postby AE25 » Sat Nov 01, 2008 9:17 am
how much are they?
can get 4.55 or 4.77 ratio out of front diff of a 4wd cr30 townace/masterace van. the chassis code will say F252 or F253 for the 4.55 and F362 for 4.77
E2 & E7 fanatic
AE25
Postby Truenotch » Sat Nov 01, 2008 1:59 pm
Also, AJPS in Australia can do a 4.77 cwp for a lot cheaper then Palmside.
Truenotch
Postby beeker » Sat Nov 01, 2008 2:02 pm
Truenotch wrote:Also, AJPS in Australia can do a 4.77 cwp for a lot cheaper then Palmside.
Is there a difference is quality ?
06 RS4 Avant
beeker
Postby beeker » Fri Nov 21, 2008 7:37 pm
bump, still want a diff head (carrier).
06 RS4 Avant
beeker
Postby Mr Revhead » Fri Nov 21, 2008 11:51 pm
the 4.77 ratios sold by palmside are toyota genuine ones...
have you tired contacting the forum sponsor?
Postby beeker » Sat Nov 22, 2008 6:29 am
Mr Revhead wrote:the 4.77 ratios sold by palmside are toyota genuine ones...
nope, will do. but need a diff head / carrier to fit it into. Already got a spare housing. Building up a complete new/spare read end.
06 RS4 Avant
beeker
