#2+3 go to a dash plug i think so im guessing 1 of them is an exciter and the other is the dash light but im not sure which 1
IKE86 wrote:#1 goes straight to the battery
l1ttle_d3vil wrote:Not sure if you have the original plug or not, but if you do:
thick white is the Batt feed
black/yellow is your Ign feed
creamy yellow is the warning light feed
mr30%jr wrote:l1ttle_d3vil wrote:Not sure if you have the original plug or not, but if you do:
colours change thru the years.
rwd_mayhem wrote:Do you know what my ones are? my charge light comes on when running, not sure if it is actually charging or not though.
