Where to buy trolley jack?
Postby Twolitre » Thu Dec 11, 2008 12:30 am
Well it's come time (xmas) to replace my trusty old trolley jack.
The only jacks I can seem to find are the pathetic little ones that look like they're only suitable for changing a tyre or the big f*ck off ones which are completely impractical for moving around my garage, picking up and putting in the car, carrying up the driveway etc.
My jack can go to 420mm raised which is good enough for me and yet isn't too bulky.
Twolitre
Postby Crampy » Thu Dec 11, 2008 3:37 am
I remember seeing a pretty good one last time I was at BNT from memory.
Crampy
Postby Dazed&Confused » Thu Dec 11, 2008 8:32 am
I work at BNT and can recommend the trolley jacks we sell 8)
Dazed&Confused
Postby xsspeed » Thu Dec 11, 2008 9:10 am
Are they 3 ton, lift to around 520mm?
Postby Adydas » Thu Dec 11, 2008 11:21 am
Ryan i think have one of these at work if i recall it was $189 with jack stands but im sure id be able to get it a bit better, Question is if we returned the stock or not.
Adydas
Postby Twolitre » Fri Dec 12, 2008 12:10 am
Dazed&Confused wrote:I work at BNT and can recommend the trolley jacks we sell 8)
Hey mate could you get me a couple of prices and any specs? cheers
Twolitre
Postby Sick Puppy » Fri Dec 12, 2008 1:06 am
How about a group buy? :lol:
Project thread here
Discussion thread here
Sick Puppy
Postby Truenotch » Fri Dec 12, 2008 12:40 pm
Can do a good 3.5 Tonne with quick lift pedal for $199. Cheaper of more people were interested.
Truenotch
Postby neo » Fri Dec 12, 2008 1:12 pm
Truenotch wrote:Can do a good 3.5 Tonne with quick lift pedal for $199. Cheaper of more people were interested.
Photos or it will never happen..
I want to get another trolley jack also.. needs to be of the low-profile design with good lift.
Something semi-alloy would be nice, but not the quicklift variety.
neo
Postby Dazed&Confused » Fri Dec 12, 2008 1:45 pm
xsspeed wrote:Are they 3 ton, lift to around 520mm?
Our 3 tonners lift to 425mm, 6 tonners to 605mm.
Also can do high lift 2 tonners to 800mm
There are a few options, just give your local BNT a ring :)
Dazed&Confused
Postby Dazed&Confused » Fri Dec 12, 2008 1:46 pm
Sure what you need? PM me :wink:
Dazed&Confused
Postby Truenotch » Fri Dec 12, 2008 4:58 pm
Ours lifts 145-500mm. $199.
Or there is an aluminium option, which is 3 tonne, low profile and will lift from 105mm to 470mm . 33kg (19kg lighter then non alloy powerbuilt one). Usually $549 - Toyspeed Special $499
Powerbuilt Low pro 90-510mm Steel, long handle, overload protection valve, 52kg. $449.
Truenotch
Postby Bling » Fri Dec 12, 2008 5:43 pm
I have this one, but without branding, its EXACTLY the same though and only cost $300 from local auto spares shop a few years back. Its a good jack, its only downside is the weight :x
Postby mr30%jr » Sat Dec 13, 2008 9:00 am
most jacks over 2.5 tonne are a bitch to carry ive got a supercheap 2.5 tonne one and its done me a mint. lifted millions of cars.
mr30%jr
Postby stalker » Sat Dec 13, 2008 9:17 am
I got one of these from ripco, and have had nothing but isses with it since!
Jack the car up, and by the time you have undone the nuts and removed the wheel and go to put the new wheel on, the whole thing has lowerd itself and is sitting to low to put the wheel on! lol.
And the main reason I got this was cause it was a "Low profile" jack, but the middle part where it goes up to allow for the pivot bolt (if people know what the hell im talking about :lol: ), is to high! it hits on the body kit and is unusable!!
worth spending the extra $50 to buy that aluminium one!
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby Bling » Sat Dec 13, 2008 11:19 am
stalker wrote:And the main reason I got this was cause it was a "Low profile" jack, but the middle part where it goes up to allow for the pivot bolt (if people know what the hell im talking about :lol: ), is to high! it hits on the body kit and is unusable!!
Yep I find that too :oops: Fine if you need to jack a car from the door sill though as its front section is very low. I used to get the jack under the front of my car, but now it scraps then hits on the grease nipple :evil:
Postby Truenotch » Sun Dec 14, 2008 4:48 pm
stalker wrote:I got one of these from ripco, and have had nothing but isses with it since!
tried bleeding it? It's pretty easy to do.
http://www.hyjacks.com/H7.HTM
Otherwise you could have a problem with your ball valve setup.
Truenotch
Postby stalker » Sun Dec 14, 2008 7:36 pm
Truenotch wrote:tried bleeding it? It's pretty easy to do.
Ahh true...no I havent tried that.
Cheers for the heads up. Will give that a go.
stalker
Users browsing this forum: No registered users and 34 guests
