Grrrrrrr! wrote:Check every earth on the motor/gearbox and computer. after that... good luck, electrical problems are always shite to find
facory pumpIf you are not running a factory fuel pump
yea the engine is eatrhed well, batterys in the boot and has a huge earth atached to the gearboxA bad earth connection rarly if ever causes a fuse to blow.
does it blow once u turn on the radio? with lights on?
ill give this a go next weekend, cheersThe trick to finding blown fuses is to replace the fuse with a highish wattage 12V bulb.
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
